Please, do not reply for this. I designed a simple delay circuit based on current source topology. A current source guarantees mute current remains constant.edbarx said:If anyone can provide a simple one transistor circuit for that, please post. Pin 8 requires a current >= 0.5mA to flow out towards the negative rail for mute to be disabled.
Please, someone who happens to know, reply to this simple question, yet google.com couldn't link to an answer!
I am building a PCB for LM3886 amplifier but I have no idea how I must connect the input electrolytic capacitors.
Which capacitor terminal, anode or cathode should be connected to the non-inverting input? A 1k resistor is between user input and non-inverting terminal, a 22k resistor is between user input and ground. The capacitor will be connected to user input. Which capacitor terminal goes there?
Google is only good to give adverts and links to buy ready made products.
First G-hit is the LM3886 data sheet, font of all wisdom.
It obviously depends if you are powering bipolar supply or single supply.
For single supply Fig 3 is your guide.
For bipolar supply, look at the basic operation. Both inputs should sit at "zero" DC. The datasheet doesn't even use capacitors. I'm paranoid so I like caps. With near-zero DC voltage a Film cap would be preferred; electros like some steady DC on them. However modern electros don't need it so much. Bi-Polar electros are available. However for the expected <1V DC here, plain electros will work *either way*. (It takes more than a Volt of reverse bias to break down.)
Finally, study the Internals, page 7. The inputs are NPNs. If you connect a resistor to zero-volt ground, the base current will drift the bases slightly -negative-. This can guide your cap polarity. How much? Input bias current is as-much-as 1uA. Given 22k resistor, this is 22mV.
PRR said:For bipolar supply, look at the basic operation. Both inputs should sit at "zero" DC. The datasheet doesn't even use capacitors. I'm paranoid so I like caps.
Code:
$ dict paranoid
3 definitions found
From The Collaborative International Dictionary of English v.0.48 [gcide]:
paranoid \par"a*noid`\, a.
1. (Med.) Affected with paranoia; as, a paranoid
schizophrenic.
Syn: paranoiac.
[PJC]
2. Suffering from delusions of being persecuted by the
conspiratorial actions of others; having an unwarranted
suspicion of the motives of others; -- used loosely in a
negative sense, not as a medical term; as, just because
you're paranoid doesn't mean they are not out to get you.
[Colloq.]
[PJC]
From WordNet (r) 3.0 (2006) [wn]:
paranoid
adj 1: suffering from paranoia
n 1: a person afflicted with paranoia [syn: {paranoid},
{paranoiac}]
From Moby Thesaurus II by Grady Ward, 1.0 [moby-thesaurus]:
25 Moby Thesaurus words for "paranoid":
brain-damaged, brain-injured, catatoniac, catatonic, certifiable,
certifiable case, disturbed, manic-depressive, mental, mental case,
mentally ill, mentally sick, neurotic, paranoiac, psycho,
psychopath, psychopathic, psychopathic case,
psychopathic personality, psychotic, schiz, schizo, schizoid,
schizophrenic, schizy
...Shame on you.
I do not understand why you personally attack (try to shame) me. I am suspicious of your motives.
Forget prejudice and have a good laugh. Life is too short. Grab a glass of your favourite drink to celebrate, for it is festive season.
YouTube
[ Note: The video illustrates situations that serious talk can sometimes be funny. This video is NOT intended to insult but to portray that possibility. ]
Nevertheless, this project, with its double size inverted LM3886 IC pads, works. I only need to add an RC filter across the load, protect the PCB's copper tracks against corrosion, and it is done.
Well Done to DIYaudio.com for its motivating company, and surprisingly, reality can be surprising, to people like PRR. Your posts made me realise an electrolytic capacitor, is not actually needed on the input of an amplifier using a split power supply. Thanks, a lot for that invaluable tip.
Oh my God, NOW we are in trouble. Thanks, a lot for that invaluable tip.
tip verb (1)
Save Word
To save this word, you'll need to log in.
Log In
\ ˈtip
tipped; tipping
Definition of tip
(Entry 1 of 10)
transitive verb
1 : overturn, upset —usually used with over
2a : cant entry 3, tilt
b : to raise and tilt forward in salute tipped his hat
intransitive verb
1 : to become tipped : topple
2 : lean, slant
tip the scales
1 : to register weight tips the scales at 285 pounds
2 : to shift the balance of power or influence tipped the scales in favor of a declaration of war— S. F. Bemis
tip noun (1)
Definition of tip (Entry 2 of 10)
1 : the act or an instance of tipping : tilt
2 chiefly British : a place for depositing something (such as rubbish) by dumping
tip noun (2)
Definition of tip (Entry 3 of 10)
1 : the usually pointed end of something a pencil tip
2 : a small piece or part serving as an end, cap, or point
on the tip of one's tongue
1 : about to be uttered it was on the tip of my tongue to say exactly what I thought
2 : just eluding recall
tip verb (2)
tipped; tipping
Definition of tip (Entry 4 of 10)
transitive verb
1a : to furnish with a tip
b(1) : to cover or adorn the tip of
(2) : to blend (furs) for improved appearance by brushing the tips of the hair with dye
2 : to affix (an insert) in a book —often used with in
3 : to remove the ends of tip raspberries
tip verb (3)
tipped; tipping
Definition of tip (Entry 5 of 10)
transitive verb
1 : to strike lightly : tap
2 : to give (something, such as a baseball) a glancing blow
intransitive verb
: tiptoe
tip noun (3)
Definition of tip (Entry 6 of 10)
: a light touch or blow
tip noun (4)
Definition of tip (Entry 7 of 10)
1 : a piece of advice or expert or authoritative information
2 : a piece of advance or confidential information given by one thought to have access to special or inside sources
tip verb (4)
tipped; tipping
Definition of tip (Entry 8 of 10)
transitive verb
1 : to impart a piece of information or advice about or to —often used with off
2 chiefly British : to mention as a likely candidate, prospective winner, or profitable investment : tout sense 1
tip one's hand or less commonly tip one's mitt
: to declare one's intentions or reveal one's opinions or resources the Justice Department wouldn't tip its hand by saying what its next move … would be — Newsweek
tip verb (5)
tipped; tipping
Definition of tip (Entry 9 of 10)
transitive verb
1 : to give a gratuity to
2 : give, present this crew has tipped you the black spot— R. L. Stevenson
intransitive verb
: to bestow a gratuity
tip noun (5)
Definition of tip (Entry 10 of 10)
: a gift or a sum of money tendered for a service performed or anticipated : gratuity
Other Words from tip
Noun (2)
tipped \ ˈtipt
\ adjective
First Known Use of tip
Verb (1)
14th century, in the meaning defined at transitive sense 1
Noun (1)
1673, in the meaning defined at sense 1
Noun (2)
14th century, in the meaning defined at sense 1
Verb (2)
14th century, in the meaning defined at sense 1a
Verb (3)
1567, in the meaning defined at transitive sense 1
Noun (3)
15th century, in the meaning defined above
Noun (4)
1567, in the meaning defined at sense 1
Verb (4)
1883, in the meaning defined at sense 1
Verb (5)
circa 1610, in the meaning defined at transitive sense 2
Noun (5)
1755, in the meaning defined above
History and Etymology for tip
Verb (1)
Middle English
Noun (2)
Middle English; akin to Middle High German zipf tip, Old English tæppa tap — more at tap entry 3
Verb (2)
Middle English tipped having a tip, from tip entry 3
Noun (3)
Middle English tippe; akin to Low German tippen to tap
Noun (4)
origin unknown
Verb (5)
perhaps from tip entry 5
Learn More about tip
Share tip
Post the Definition of tip to Facebook
Share the Definition of tip on Twitter
Time Traveler for tip
The first known use of tip was in the 14th century
See more words from the same century
Watch More on tip
No, we are not. His advice is good advice, and well appreciated, although I do not always like the way he writes.JMFahey said:Oh my God, NOW we are in troubleedbarx said:Thanks, a lot for that invaluable tip.
Good advice is good advice, irrespective of who writes it.
- Chip Amps
- What to do about mismatched IC footprints?
