Bob Cordell's Super Gain Clone PCB (LM3886) and a stripped-down version: Compact3886
Old 17th July 2020, 12:57 AM   #251
kp93300 is offline kp93300  Malaysia
Want to thank Mark for the pcb and the support. Nice calm and quiet amp that l like. Very detail and precise amp. Worth casing up
Old 17th July 2020, 01:15 PM   #252
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
VERY nice build, kp93300! I'm happy to see that you added your own personal touch. SMD bypass capacitors, then beeswax(?) to fix the coil turns in place, rather than Kapton tape. Good on ya!
Old 17th July 2020, 04:05 PM   #253
6L6 is offline 6L6  United States
6L6's Avatar
Looks good!!
I’ve been having very good luck with MeanWell power supplies, how are those?
Old 18th July 2020, 12:40 AM   #254
there is a little bit of buzz with ears right close to the markaudio 12 p speakers with the input shorted.
Otherwise, it sound very natural across the entire frequency range . BIG soundstage wll beyond the speakers and music surrounds you .
The amp and power supply generate almost no perceptible increase in temperature after many hrs of use.
I use AB epoxy resin glue to keep the inductor in place.
Old 5th August 2020, 01:56 AM   #255
l replace mute resistor R17 with a combination of 22V zener diode in series with 22k resistor.
the switch on and off thump is removed but it sounds muffled and of low volume.
Is the problem due to the placement of C23 ?
Old 5th August 2020, 02:04 AM   #256
Dadbeh is offline Dadbeh  United States
Dadbeh's Avatar
what is the point of the caps on the speaker outputs?
Old 5th August 2020, 03:35 AM   #257
asuslover is offline asuslover  Romania
I believe that's the input cap and not the output, I guess they were a little large to fit on the board.
Old 5th August 2020, 04:10 AM   #258
yes.
These are input caps for testing and trying . Not ideal but will solder on board once l made up my preference
Old 21st August 2020, 06:58 PM   #259
bobberner is offline bobberner  United States
Default First attempt at this
Hello all!
I just received my parts for the Super Gain Clone and PS, well except for the chassis and some out of stock caps on the way from digikey. If I may ask a very basic question, what is the difference between this and the Amp Camp amplifier. Other than the internal PS, 40 watts vs 8 watts, and number of parts involved? The price seems to be about the same, well at least the same order of magnitude anyway.
www.bigwoodstudio.net Building speaker enclosures for others. Selling Frugel-Horn kits.
Old 21st August 2020, 07:12 PM   #260
Mooly's Avatar
Where to even start...
The ACA is a niche product that caters for those who want to go down the low power Class A single ended route. By that very definition the ACA runs hot, it has a low power output that is greatly affected by whatever you hang on the end of it but when all that is said and done it can sound truly wonderful and really engaging.
The LM3886 based design is, whichever way you flip it, a chip amp. That means cool running and efficient (compared to the Class A) and this one has an output that is not affected by what you dangle on the end of it. It has lower distortion, much better drive ability... but does it sound as good?
They will certainly sound very different one vs the other. Only you can decide which you prefer
Bob Cordell's Super Gain Clone PCB (LM3886) and a stripped-down version: Compact3886Hide this!Advertise here!
WTB: Chips for chip amp -- gain clone gainclone -- lm3886 Jimmy154 Swap Meet 0 6th July 2014 02:53 PM
FS 6 Channel LM3886 (ELAN)Gain clone gaborbela Swap Meet 22 24th November 2011 02:23 AM
First Audio Circuit (Gain Clone w/LM3886) milsman2 Chip Amps 10 10th August 2011 05:48 PM
FS: LM3886 Gain Clone Chips (19) bolserst Swap Meet 5 26th October 2008 06:35 PM
LM3886 gain clone vs STK4048XI for 4 ohm load filgor Chip Amps 0 25th September 2004 12:05 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
