bridged LM1875 >>ASYMMETRY<< issue
Old 10th October 2019, 07:52 AM   #11
ubergeeknz is offline ubergeeknz  New Zealand
Not quite sure why you want to drive power transistors off the transformers still. What do you want to achieve?
Old 10th October 2019, 07:54 AM   #12
Also worth noting, transformers "reflect" impedance. So with nothing on the secondaries of those transformers, you may get strange results. Try putting the expected load on the secondaries so that the impedance is reflected on the primaries.
Old 10th October 2019, 10:23 AM   #13
johnnyhou is offline johnnyhou  United States
Honestly, I have not had any luck building a discrete power amplifier as of yet, at least I learned enough to check hfe for matching transistors for LTP but no actual working circuit as of yet. I suppose I got lucky with the first transformer coupled attempt getting a pretty darn good sounding 100 watt amp from 30-0-30 supply. I am hoping to quadruple that number but my transformers have to be right on the money to get those power transistors to deliver. Stumbled on issues with impedence reflection through transformers so that is why I am using 2 seperate, identical transformers tying their primaries together in series and using lm1875 drivers in BTL mode to get the voltage swing as high as possible. A 5:1 ratio on the transformers brings the voltage and current into range to drive the power transistors in common emitter mode class AB arrangement for what I hope to be somewhere in the range of 300 - 500 watts.
I have breadboarded the digi125 and aksa-55 but did not work. I am learning though. No problem setting up working simulations in LTSpice, shouldn't be long before I start having some success with the discrete amps. Anyway, thanks again for sharing.
Old 10th October 2019, 10:28 AM   #14
A very interesting approach... Will be pretty cool to see what you come up with. Have fun with your project.
Old 12th October 2019, 10:35 PM   #15
Mark Tillotson is offline Mark Tillotson
C2 and C7 are an order of magnitude too small, so at LF there will be asymmetry due to mismatched electrolytics and the LF roll off starts too soon.
R4 and R6 seem suspiciously small. 100nF / 10 ohms are by far the commonest Zobel network used and for good reason.
bridged LM1875 >>ASYMMETRY<< issueHide this!Advertise here!
LM1875 Whooshing, Noise issue 6Leinad7 Chip Amps 23 31st December 2016 09:36 PM
lm1875 bridged, single supply voltage dutchess Chip Amps 41 22nd March 2014 07:06 PM
LM1875 Ground issue Havoxx Chip Amps 22 10th August 2011 12:35 PM
Bridged Amplifier with LM1875 corralluis Chip Amps 0 28th April 2011 09:11 AM
Copyright ©1999-2019 diyAudio
