eBay mono LM1875 kit
Old 26th June 2020, 07:40 AM   #721
Sadface is offline Sadface  New Zealand
There is always Carlos' dual LM338 regulator circuit.
LM338 can handle up to 5A but you would need a sizeable heatsink.
At 5A you would be dissipating 50w at the regs.
I've used the circuit successfully to power 2x LM1875 albeit nowhere near that amount of current.
Old 26th June 2020, 10:19 PM   #722
FauxFrench is online now FauxFrench  France
Originally Posted by Clueless but avid View Post
Another Question: Is it possible to use a Cap Multiplier to get rid of those 3-4 Volts? If so, how should it look?
You do not really have sufficient drop-voltage for a cap multiplier that has real filter effect. You can put "voltage dropper" circuits between the outputs from the rectifier bridge and the power rail decoupling capacitors. You could also just use drop-diodes connected in series but the "voltage dropper" circuit is more compact and easier to cool in a controlled manner.
Use Darlington power transistors rated for some 10A, in a TO-220 housing, and ordinary 2V7 zener diodes.
Old 27th June 2020, 12:05 AM   #723
vilding is offline vilding  Sweden
Thanks FF and rabbitz!
Sound advise as always. Can't find a recommendation for the smps but going on Rabbitz ≈chart, I'll probably go for 5A since it's rated at 300w.
Started reading the circuit protection article at ESP now. Really good source of educational material!
Old 30th June 2020, 02:52 AM   #724
Clueless but avid is offline Clueless but avid  Germany
Many Thanks @ FauxFrench for the Voltage Dropper.
eBay mono LM1875 kitHide this!Advertise here!
LM1875 Ebay dual channel pcb question nenad88 Chip Amps 11 29th August 2018 11:21 PM
Chinese Mono LM1875 Board Twil Chip Amps 54 23rd April 2018 08:04 AM
ebay lm1875 pcb asuslover Chip Amps 7 27th August 2016 03:58 AM
Running two LM1875 mono amp from single psu si82 Chip Amps 21 2nd June 2014 03:32 PM
Just fired up my new dual mono lm1875 Gainclone. Shoog Chip Amps 5 19th January 2004 06:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
