eBay mono LM1875 kit
Old 21st September 2019, 01:40 AM   #161
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
The 0R1 resistors reduce high order harmonics from the rectifier and mains and the DC waveform is much cleaner (quoted from source).
Chris
I've added a schematic of the power supply to clarify my comment. You wanted to use the FC closest to the transformer, so they would be C1, C2 and the FW would be C3, C4, C5, C6.
I'm only an amp builder and have picked up this stuff over the decades but I do not pretend to understand it. Hugh Dean (AKSA) has tried to explain this stuff to me but it just shoots over my head. My expertise is in speaker design and build.
If there are no dogs in Heaven, then when I die I want to go where they went - Will Rogers
Old 21st September 2019, 10:14 AM   #162
chermann is offline chermann  Austria
Thanks rabbitz for clarifying and sharing.
I really appreciate your help
Old 26th September 2019, 11:10 AM   #163
Hi again
Actually my time schedule for DIY audio is not very good...actually i am busy.....
i send you a pic (evening) from the cap bank update according to rabbitz idea. done by my son under my advises
chris
Old 26th September 2019, 07:23 PM   #164
Default not ready...
Hi
as promised..pics from the dual supply with 1 cap bank. the blue caps in the middle will be connected to the rectifiers +/- pole. the gold caps are for each amps and each side i get the +25V - 0 - -25V. i plan to solder the wires under the pcb red-black-blue on each side
R = 0,2R/5W...from my stock..
chris
Old 26th September 2019, 07:38 PM   #165
Hi
i have on hand a KBPC604. so its rated for 400V and 4Amps..but i am sure its too small = 4 Amps is too less current..
https://www.vishay.com/docs/93585/vs-kbpc1series.pdf
Old 27th September 2019, 02:25 AM   #166
rabbitz's Avatar
ESP recommends a 10A minimum bridge rectifier. I used 35A on my 120VA 18-0-18 transformer but I did use a 6A on my small 20VA 15-0-15 transformer supply but did add a heatsink to it in case. It never got warm during tests.
Old 27th September 2019, 02:30 AM   #167
rabbitz's Avatar
Originally Posted by chermann View Post
Hi
chris
Looks good. Don't forget the transformer CT has to go in at the centre blue caps.
Old 27th September 2019, 05:42 AM   #168
Thanks rabbitz - i am looking for one phase 10A rectifier
Old 27th September 2019, 05:42 AM   #169
yep Sir !
Old 28th September 2019, 06:22 PM   #170
Default small step forward
Good evening
here some pics from a small step forward.
transformer mounted, speaker terminal, rca terminal, power socket with switch,
rectifier mounted
the rectifier is a diotech KBPC 2504....25A version with alu bottom plate- it was the only version which was today available
my cap board gets 2 leds = red for +25V and yellow for the -25V
chris
eBay mono LM1875 kitHide this!Advertise here!
LM1875 Ebay dual channel pcb question nenad88 Chip Amps 11 29th August 2018 11:21 PM
Chinese Mono LM1875 Board Twil Chip Amps 54 23rd April 2018 08:04 AM
ebay lm1875 pcb asuslover Chip Amps 7 27th August 2016 03:58 AM
Running two LM1875 mono amp from single psu si82 Chip Amps 21 2nd June 2014 03:32 PM
Just fired up my new dual mono lm1875 Gainclone. Shoog Chip Amps 5 19th January 2004 06:09 PM
Copyright ©1999-2019 diyAudio
