High Bias LM3886 anyone?
Joined 2011
Seems difficult. First of all the LM3886 is decompensated and can't be run at unity gain like the circuit you linked. So you'll need extremely well matched resistors to set the gain=10.00 of each one. Second, the ballasting resistors R1 and R2 probably need to be less than 15 ohms if you're driving a 4 ohm loudspeaker at the output. This means the class-A bias current (=Vdiode/(R1+R2)) will be uncomfortably large unless you abandon the diode and build a precision level shifter with a much smaller voltage drop.
Haven't tried it myself.
Administrator
Joined 2007
Interesting idea and yes it can be made to work in theory. The 500uF caps are needed to minimise offset currents.
Unity gain buffer:
Joined 2011
With +/- 35V supplies that's ~13 watts of class A dissipation in each of the two LM3886's. Gulp!
In the left chip U1 the output stage pullup carries 370mA more current than the pulldown.
In the right chip U2 the output stage pulldown carries 370mA more current than the pullup.
Administrator
Joined 2007
:) gulp indeed.
This shows the set up with the two chips (first images) and then just one chip used normally. So it does kind of lower distortion. I also should have used a more appropriate value for the 1nF.
The FFT shows 'odds' predominate in the twin chip version.
... Second, the ballasting resistors R1 and R2 probably need to be less than 15 ohms if you're driving a 4 ohm loudspeaker at the output.
Did you even bother to read my post, I suggested .1 - .5 ohms for those resistors in a power
amp application. Yes, it would need to be designed for more than unity gain, and of course
the diode bias would be adjusted to get whatever level of class A bias that one wants within
the capability of the part and heatsinking.
@Mooly nice work on the sims, thanks!
Joined 2011
and of course the diode bias would be adjusted to get whatever level of class A bias that one wants within the capability of the part and heatsinking.
Mooly adjusted the diode bias by: doing nothing. The cost was 13 watts in each of two LM3886's. The benefit was: simplicity. It functioned properly in simulation.
Another possible adjustment is to use a high precision shunt voltage reference IC such as the LM4040AIZ-1.2 (thru hole packaging, ±0.1% tolerance, 1.225V, max current = 25mA, $1.87 qty=1) instead of a diode, with a high precision resistive voltage divider, to select exactly abc.de% of 1.25V as the levelshift amount. This chip is on the shelf at DigiKey (link) and Octopart.com can tell you where else it's available. Tune the class-A quiescent power dissipation to whatever number you wish, merely by twirling the shaft of a 25-turn trimmer potentiometer.
Haven't done this myself.
Once upon a time, I fooled around with two tda2030 and a Vdiff at the inputs, and of course gain in the nfb. Too fiddly with the nfb (for me); a chipamp isn't behaving like a normal opamp in this regard.
A simplification would be to "attach" a CCS to the output of a chipamp. For example with a single-ended cap-coupled tda2030 amp, you just need to add a to220 PNP current sink to the output, and there you go. PNP to220 tab goes directly to gnd; can be fixed directly to the heatsink just like the chipamp. Cheaper, faster, smaller, less trouble.
Joined 2011
Sounds a lot like Douglas Self's "XD" crossover displacement. The patent appears to have "ceased" / "expired" .
_
anyone with experience of the 3886 cm range in unity gain? (with noise gain compensation)
the data sheet cmrr spec seems to have been measured with +/-20 V and 80 V total supply
which would need a audio frequency gain of 2 (not unreasonable as DC gain - lots matched value resistors, not too high a Vos multiple)
I'm not likely to add a lot to this thread, or be very responsive since shingles ripped up nerves in my right arm and the pain management drugs don't seem good for concentration
get the new Shingrix vax - recommended now for those over 50
