LM1875 Power supply
I stay in region (India) where AC supply is 230V but all toroidal transformer are 115V , I want to make a power supply.
Is this transformer look good ? I never heard of this brand.
https://in.element14.com/multicomp/mcta030-12/transformer-toroidal-2-x-12v-30va/dp/9530304
That will work, but at 30 VA that one has enough power to supply only one LM1875, if you are building a stereo amp you will need one of those for each channel, or get a transformer with a higher VA rating.
Mike
PRR
Joined 2003
Administrator
Joined 2007
12 volt windings are going to give around -/+ 17 volts DC or 34 volts in total. That's maybe not such a bad thing for a starter project and it would allow a modest output of around 12 to 15 watts RMS into 8 ohm.
It really all depends what you want from the project.
I just want clean 10w of power at max , then not a issue .
Now one thing , anyone can recommend me a good diode bridge ?
I always combined four 1N4007 as a kid but that not a good rectifier for audio I believe but fine to drive leds on school fest .
