'Best' LM3886 PCBs (both single & parallel)
Old 24th June 2019, 11:01 AM   #1
lost eden is offline lost eden  United Kingdom
Default 'Best' LM3886 PCBs (both single & parallel)
I'm in the process of (re)building a three channel LM3886 amp which uses two single LM3886 PCBs for the left/right mid/high channels & one dual (parallel) LM3886 PCB for the sub channel.
My previous LM3886 used the single XY boards with no problems, but this time round I went for the boards from KMTech as he sells single boards, parallel boards & an active crossover board. I've run into a number of issues with them however, namely that the position of the thru-holes for the LM3886 are too far from the edge of the PCB so the ICs don't sit flat against the heatsink (I've come across another post here on the forums from somebody who ran into the same issue) & with the parallel board the mute circuitry isn't actually implemented & the board has to be modified to make the amp actually make noise.
At this stage I honestly just want to drop the KMTech boards & start afresh with stuff that actually works from the get go, rather than try to file down the PCBs, tack the mute circuitry onto the IC on the bottom of the board, etc. So what right now are the de facto 'good' PCBs for individual & parallel (two IC) LM3886 boards? I don't mind if it's something I can buy on eBay/AliExpress or a community design that I can order to get made from JLCPCB.
Old 25th June 2019, 07:34 AM   #2
tomchr is offline tomchr  Canada
tomchr's Avatar
You can consider my LM3886 Done Right. Or, if you prefer truly stellar performance, my Modulus series. The Modulus amps use error correction to eliminate the distortion caused by the LM3886. My Modulus-286 uses two LM3886es for higher output power and employs error correction as well. For even higher output power, I offer the Modulus-686. You'll get nearly 400 W into 4 Ω at about -120 dB THD. For a "safe-n-sane" build, you can lower the supply voltage a bit and get, say, 125 W (8 Ω), 200 W (4 Ω) without much fuss.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD. HP-1: 3W/20Ω, -130dB THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 25th June 2019, 03:09 PM   #3
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
I'm offering this bit of info for you purely based off of listening to the Modulus-686 amps with the LXmini setup at Burning amp last year, and based on tomchr's work put into them- they are one of the best amplifiers I have ever heard, period. Either of his designs based on the 3886 would be fantastic, but it just depends on your budget.
I'm a die-hard tube guy but I still heartily recommend the Neurochrome stuff to anybody interested in building solid state amplification. I even added a few genuine TI 3886 IC's to the kits he put in the raffle at burning amp last year
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 25th June 2019, 03:49 PM   #4
00940 is offline 00940  Belgium
00940's Avatar
Strangely, there aren't many parallel boards floating around. You could always build single boards with 0.1% resistors to set the gain and just add 0.22r output resistors to balance things out.
As posted above, the modulus serie is really the best you can get with chipamps. If you're looking for something more pedestrian, maybe have a look here: An open source LM3886 chip amplifier. – (mis) Adventures in Hi-Fi
All that is excessive is insignificant. Talleyrand
Old 25th June 2019, 07:31 PM   #5
The Neurochrome stuff certainly looks nice & I'm sure the prices are justified by the amount of development that went into them, but $39 per unpopulated board for the LM3886 Done Right is just too much for me, let alone the Modulus boards.
That open source PCB is just the sort of thing I'm looking for though! To parallel two of them together, is it literally just a case of joining their outputs via low value resistors (the KMTech parallel board I have uses 0.1r 3W) or is there more to it?
Old 25th June 2019, 10:16 PM   #6
00940's Avatar
Well, there is a bit more to it.
- You want the gain of the paralleled amps well matched so use 0.1% resistors in the feedback.
- Build 4 identical amps and measure the two with the most similar dc offset. Use these for paralleling.
- Without a servo, I would use 0.2r resistors (at least 3W, better 5W). If possible 1% tolerance.
Old 26th June 2019, 07:46 AM   #7
tomchr's Avatar
Getting multiple LM3886es to play nicely in parallel is not an easy task. You need to connect them together with ballast resistors (0.1-0.33 Ω). That's the easy part. You then need to minimize their DC offsets. That can be accomplished in many ways. Some simple and a bit crude (set the DC gain to unity) others more complicated (DC servo). The closer you can get the DC offset to match between amp sections, the smaller you can make the ballast resistor.
Also beware that two or more LM3886es in parallel can enter a latch-up condition on startup if the negative rail starts up before the positive. This is not likely an issue if you're using an unregulated supply, but can be an issue if you're using an SMPS or other type of regulated supply. In my Modulus-286 and -686, I chose to add a few components to make sure the modules behave nicely even if the positive and negative supplies goes away or comes up late.
If you're looking for a "community designed" version, 00940's layouts would be my recommendation.
Tom
Old 26th June 2019, 09:21 AM   #8
I've ordered 5 of 00940's layouts from JLCPCB, I'll build four of them & then see how close the DC offsets are & what lengths I need to go to in order to successfully parallel 2 of them. Thinking about this I now understand better why Crown Macrotechs used to have their TO-3 output devices colour coded or numbered in the factory, according to their tolerances, so that the amps supported parallel mono operation in addition to bridged mono. I've been looking through the thread on 00940's layout but I've not yet come across a list of recommended component values?
I'm assuming 'DC servo' is not referring to the same little servo motors I use in my model planes...?
Old 26th June 2019, 09:33 AM   #9
NealJ is offline NealJ  United Kingdom
'Best' LM3886 PCBs (both single &amp; parallel)
There's one on the (mis) Adventures in HiFi website that 00940 put together from Mouser
Old 29th June 2019, 03:37 PM   #10
tomchr's Avatar
That's a valid assumption. An image search for "DC servo amplifier" will give you some schematics. You may also find National Semiconductor (now TI) Application Note AN-1192 informative. They used the LF411 in the DC servo. It was great in its heyday, but something like the OPA277 would improve the DC performance considerably.
Tom
'Best' LM3886 PCBs (both single &amp; parallel)Hide this!Advertise here!
FS: LM3886 PCBs alexcp Swap Meet 3 12th June 2018 05:22 PM
FS: Full set of Neurochrome PCBs (Parallel-86, Power-86, THAT Rx) FJHookah Swap Meet 5 7th July 2016 08:15 PM
WTB - 2x Parallel-86 PCBs only pinnocchio Swap Meet 2 20th January 2016 12:13 AM
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 24 21st October 2013 05:50 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Copyright ©1999-2019 diyAudio
