TDA2030 Single Supply Problem
Old 19th June 2019, 09:04 PM   #11
TK2 is offline TK2
Yup one problem Ray,, Bad cap,, I checked that thing about 10 times.. everything I tested it on said it was good.. Aaaaaarrgh!,,, So Changed the cap and found another problem.. Wrong Node. Eeeeek,, LOL Thank you for your help,,, Super appreciate it.
Old 19th June 2019, 09:07 PM   #12
rayma is offline rayma  United States
Breadboards can be a real problem. The silk screen normally on pcbs is a real help.
Old 19th June 2019, 09:07 PM   #13
TK2 is offline TK2
Hi JM,, Yes,, Cap connected to the wrong end or node as Ray would put it.. along with a bad cap,, Circuit works great,, I just have to increase the supply voltage up tor around 20 volts from 15volts,, Circuit is clipping slightly when input signal is over . 5 volts.. Thank you for your Help.
TDA2030 Single Supply ProblemHide this!Advertise here!
supply problem bunty Power Supplies 4 6th October 2013 02:56 AM
supply power problem captaincrazy Power Supplies 5 18th February 2013 02:52 PM
Faulty supply problem somejohndoe Power Supplies 62 20th January 2011 09:42 PM
UcD 180 Supply ST problem aluaudio Class D 0 6th April 2010 12:54 PM
Power supply problem Niila Tubes / Valves 6 12th April 2008 01:39 AM
Copyright ©1999-2019 diyAudio
