Distorting amp
Distorting amp
Old 4th June 2019, 05:42 AM   #1
goodguys is offline goodguys  United Kingdom
Default Distorting amp
Hi And thanks for reading.
I have a polk audio RT3000P active sub and there is something wrong with the amp board. When the volume is low the sub works fine, but when i raise the volume to about 30 watts the sound starts distorting. Have checked the drive units and they are fine, also checked mains power supply capacitors and they are good.
I did read somewhere that someone repaired this and blamed it on caps, he did a full board recap though.
What is this distorting problem indicative of.
Thanks.
Old 8th June 2019, 09:15 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I would first check on a scope you aren't going into clipping.
Maybe the driver impedanc eis too high or low for the amp.
PCBCAD51 download or CDROM October 2019 version out now ..https://www.murtonpikesystems.co.uk
Old 8th June 2019, 10:29 PM   #3
rayma is offline rayma  United States
Are you certain that the voice coil isn't rubbing?
Old 9th June 2019, 06:02 AM   #4
Thanks!
I found the problem, it is a dry joint in the power supply. The problem now is that because of this, the power board has gone all black and burnt, seems to be working though.
The drive units are okay, i hooked them up to an external amp and they sounded fine
After soldering the resistor back down the sub does sound better, just there now problems with the amp board. Looks like one problem after another. Oh well..
Distorting ampHide this!Advertise here!
Distorting 6L6 amp peterthetrumpeter Tubes / Valves 25 18th December 2018 04:41 PM
Lowther distorting..... help please? jakruby Full Range 12 12th January 2010 04:19 PM
My nad L73 Receiver amp distorting bad! kayjay75 Solid State 1 13th November 2009 09:40 AM
Meridian MCD Distorting doarkface Digital Source 0 10th February 2009 07:47 PM
Sub distorting - help please Simpleton Subwoofers 8 14th August 2005 06:56 AM
Copyright ©1999-2019 diyAudio
