TDA2030A amplifier
TDA2030A amplifier
Old 12th April 2019, 03:29 PM   #1
Anirvan is offline Anirvan
Question TDA2030A amplifier
I always love to make audio amps as I love music. So I tried making a TDA2030A amplifier and had made one according to the data sheet. I powered it using a 12-0-12 volts 1 A transformer and it worked fine. But the next day when I assembled the whole thing in a metal cabinet and powered it up again, the amp started making excessive humming and noise and finally the Chip burst with a loud pop!!
I don't know what went wrong in one day or someone cursed my amp or whatever happened.
Anyone please tell me why this happened? ?
Old 12th April 2019, 03:40 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Are you using split supply or single? If you grounded the tab, with split power, then you made a short circuit across negative bus. It's ok if the negative is grounded.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 13th April 2019, 06:52 AM   #3
I'm using +\- 12 v transformer
Old 13th April 2019, 11:48 AM   #4
Kshishtoff is offline Kshishtoff
Kshishtoff's Avatar
Anirvan, you should to have installed a dielectric pad between your chip and heatsink.
But probably I'm wrong. Photos of your amp can tell us the truth.
Sorry for my English, I'm still just learning.
Old 15th April 2019, 12:13 PM   #5
12VDC or AC at the rectifier input?. If you isolated the tab from the heat sink or the HS is in no contact with another metallic part, then there is no problem.
Perhaps a bad decoupling or wiring made it braking into oscillations.
TDA2030A amplifierHide this!Advertise here!
Single TDA2030A 5.1 amplifier help docprototype Chip Amps 3 15th September 2018 10:52 AM
TDA2030A Power Amplifier Matthewong Chip Amps 33 25th October 2012 12:36 PM
Audio Amplifier TDA2030A pixnum Chip Amps 5 27th December 2010 03:29 AM
TDA2030A Power Amplifier ali_moinuddin Vendor's Bazaar 1 24th September 2007 09:56 AM
Copyright ©1999-2019 diyAudio
