Looking for the Circuit drawing of this LM4780 Board
Old 6th August 2019, 02:35 PM   #41
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Originally Posted by Mark Whitney View Post
R13 - 14 should be 2.7 ohms.
Interesting you should note that as I've seen 10R and 2R7 (as per TI datasheet) in this location with a 100nF to make up the zobel. Have no idea if it makes much of a difference as all I've built used 2R7 but the last built module I received has 10R.
If there are no dogs in Heaven, then when I die I want to go where they went - Will Rogers
Old 29th September 2019, 04:01 PM   #42
Salar is offline Salar  Germany
I have not built the amp yet but I am wondering if the
layout of my board is good and if I should get another PCB...
When you look at my photograph from page 1,
Arenīt the inductors of the Thiele Network too close to the inputs (the white connectors in the middle) - and the feedback-resistors (I guess some of the little blue ones) too far away from the LM4780?
All the best,
Salar
EDIT: The Image might be squeezed, just click on it to see it in the correct aspect Ratio.
Looking for the Circuit drawing of this LM4780 BoardHide this!Advertise here!
SSE PCB board detailed drawing/fpd CosmikDebris Tubelab 4 16th January 2015 03:26 PM
LM4780 started drawing a lot of current tsiros Chip Amps 13 28th July 2013 01:53 PM
New HT system design added to drawing board Andy G Multi-Way 9 17th September 2005 05:34 PM
Basic circuit drawing software JDeV Everything Else 7 2nd February 2003 03:13 PM
Copyright ©1999-2019 diyAudio
