R13 - 14 should be 2.7 ohms.
Interesting you should note that as I've seen 10R and 2R7 (as per TI datasheet) in this location with a 100nF to make up the zobel. Have no idea if it makes much of a difference as all I've built used 2R7 but the last built module I received has 10R.
I have not built the amp yet but I am wondering if the
layout of my board is good and if I should get another PCB...
When you look at my photograph from page 1,
Aren´t the inductors of the Thiele Network too close to the inputs (the white connectors in the middle) - and the feedback-resistors (I guess some of the little blue ones) too far away from the LM4780?
All the best,
Salar
EDIT: The Image might be squeezed, just click on it to see it in the correct aspect Ratio.
All the best,
Salar
