6 Watt Car amp
PRR
Joined 2003
12V 4 Ohm load:
Single-ended (basic TDA2003 etc) makes 4 Watts
Bridge-mode (standard car-sound chips) makes 16 Watts (18W-24W claimed)
How nano is this nano? I would expect anything with an electric starter (or drive motor), or headlights, would not be strained by a small car-sound system.
According to a graph that I've found in a BOSCH document about car alternators, 14.4 V is the maximum allowed regulation voltage @ 20°C/293K. There's a temperature coefficient, though, of -2 mV/K. So the regulation voltage may be 14.48 V @ 253K/-20°C :rolleyes:.
Best regards!
With the efficiency of the TDA2003, which is 69%, you can get these 6W RMS on 4ohm load with 14,4V.
with 12V you will get 4,2W RMS on 4ohm as PRR stated.
About batteries and voltages which are allowed, I can discuss, but this is not the place for that. It is not the question here.
PRR
Joined 2003
I´d use any of the old school chips.
No, NONE will make 6W, not their fault but too low supply voltaghe , so don´t lose sleep about that.
Slightly rewritten goal should be: "easy simple power amps, putting out as much as possible into 4 ohm speakers when fed from car battery voltage"
By the way, TDA2003 is rated 10W into 2 ohm, so you can add an extra pair 4 ohm speakers if space is available, with no extra amp complication.
