lm3886 parallel
lm3886 parallel
Old 21st March 2019, 06:08 AM   #11
rookiesparks is offline rookiesparks  Guernsey
Originally Posted by asuslover View Post
You could easily bridge them, add drv134 and adjust the power supply voltage so it could go with your speaker impedance. Will give you 100w in 4 ohms and 120w in 8ohms.
Again , I donít think that paralleling 2 boards will work, the idea is to parallel the chips and not the boards.
thanks for your input ! i have previously made a bridge setup as you mention with drv 134 with good success ! to my ears parallell lm3886 may not be as powerfull as bridged but does have a fuller sound ( all subjected ) ime experimenting with these boards as they do sound sweet singularly ! and at the end of the day if this project is a no no i might go bridged
witout stupid people ! there wouldnt be clever ones
Old 21st March 2019, 06:22 AM   #12
Mark Whitney is offline Mark Whitney  Netherlands
Mark Whitney's Avatar
It could be anything. Have you taken any measurements? Power supplies are only 4A. You are meant to twist the power leads. Not possible to adjust the offset of each chip independently. Do I need to go on? So many bad design choices.
Regards Mark.
Old 21st March 2019, 12:43 PM   #13
viyohepav is offline viyohepav
Lm3886, you can parallel but not recommended for bridge
Taming the LM3886 Chip Amplifier
Old 21st March 2019, 01:19 PM   #14
kokoriantz is offline kokoriantz  Lebanon
If I understood , you are paralleling to drive 8 ohms load to have a higher quality rather than higher power .
Old 21st March 2019, 01:39 PM   #15
asuslover is offline asuslover  Romania
lm3886 parallel
Plz read LM3886 - Application Note 1192 - Reference Design here:
http://www.ti.com/lit/an/snaa021b/snaa021b.pdf
There are a lot of great designs around bridged lm3886 , even lm4780.
Old 21st March 2019, 02:01 PM   #16
You can do bridge, yes.
but it is not recomended because of the power consumption, its also in the link you provide section 3.
Better go for parallel or bridge parallel.
Old 21st March 2019, 11:57 PM   #17
Yes , you dissipate four times more power than a single , but keeping the same load impedance. If when bridged the load is double impedance, than total Pd becomes twice higher then a single all providing twice more power . By this Pout/Pd remains the same , each IC dissipating the same as running in single. This why the load impedance when bridged must remain higher than 8 ohm.
Old 22nd March 2019, 11:12 AM   #18
pitbul is offline pitbul
For parallel amps, resistors which defines amplification on the LM3886 should be 0.1%,
after that there are no problems with it. Load share resistors on the outputs are mandatory.
Old 22nd March 2019, 11:16 AM   #19
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by rookiesparks View Post
basically identical,,all matched on home made jig consisting of a low voltage through different resistors and taking mill / volt reading with dmm
Yes, it's not certain he's able to measure them accurately enough
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 22nd March 2019, 12:01 PM   #20
YouTube
lm3886 parallelHide this!Advertise here!
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 24 21st October 2013 05:50 PM
LM3886 parallel panson_hk Chip Amps 35 26th August 2011 12:58 AM
LM3886 x 2 in parallel jmar Chip Amps 46 24th October 2009 03:53 PM
LM3886 in parallel Denis.BR Chip Amps 11 12th August 2009 07:16 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Copyright ©1999-2019 diyAudio
