Composite amplifier: LM3886 + LME49710
Old 11th July 2019, 04:50 AM   #101
kokoriantz is offline kokoriantz  Lebanon
I don't have any experience with 24 bit , but with 16 . To get lowest closed loop distortion you must output the sine wave with the highest level to be described by 24 bit , then attenuate by resistors to get -3db FS . May be there is a minimum to search for .
Old 11th July 2019, 10:49 AM   #102
zarandok is offline zarandok  Austria
zarandok's Avatar
The Xonar D2X is a relative good card (I've it too) with PCM1796 dacs. But: the analog on-board regulator is a 7805 (!!!), and there are some lower quality ceramic caps in the signal path wher they shouldn't be... I've updated them to Elna Silmic and TPA7S4700...
There are more things in heaven and earth, than are dreamt of in your philosophy...
Old 11th July 2019, 10:56 AM   #103
zarandok's Avatar
Just let me please one queston what I do not understand:
The R23, R25... resistors with 1k (parallel with + input of LM3886) seems to be very low value for me!!! With simulations I got the best parameters with ca. 10k by this position!
Anyway, in the case of 1k you have a huge signal voltage drop..
Old 11th July 2019, 04:19 PM   #104
jeanlemotan is offline jeanlemotan
Originally Posted by tomchr View Post
For measuring a bridged amp, you need a differential input.
Tom
After the 2nd round of resistor smoke, I figured this out
I'll build a differential probe with a LME49710, 9V batteries and hand picked resistors and that's it.
Old 11th July 2019, 04:22 PM   #105
Those resistors together with R6 and R31 form 2 voltage dividers (R6+R25 and R31+R23) that is meant to allow the LME49720 to clip before the 3886. Like this I get much better clipping behavior than if the 3886 would clip.
There was some discussion about in earlier posts (Composite amplifier: LM3886 + LME49710)
Old 11th July 2019, 06:43 PM   #106
zarandok's Avatar
Thanks. What is the simulated THD+N of the whole cicruit? Could you show me a step response with about 500ns/div resolution?
Tom is using by this positions 1k-330R. Pretty low...
Old 18th July 2019, 09:24 AM   #107
The first post has the simulated step response and THD+N. Note that the TINA model doesn't include the LM3886 THD so the simulation for that is not relevant.
I got a good sound card to measure this but I'm still learning about how to calibrate the whole thing in REW...
Old 18th July 2019, 09:25 AM   #108
Just finished analyzing some NE5532 opamps that I got in a preamp. They seem to be fake, LM358 in disguise...
Here's the thread here: Fake NE5532
Old 20th July 2019, 03:10 PM   #109
zarandok's Avatar
Ok, really. But I can not see the simulated THD values still...
Old 22nd July 2019, 11:27 PM   #110
1audio is offline 1audio  United States
Actually all the DAC's and ADC's I have tested are better at a reduced level. Typically the best distortion is at -15 dB. This brings a penalty in SNR but for distortion testing a good FFT program will get you past that limitation. The best I have used for this is: DiAna, a software Distortion Analyzer DiAna Index of /diana/
Demian Martin
Product Design Services
Composite amplifier: LM3886 + LME49710Hide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2421 17th May 2019 12:10 AM
LM3886 & LME49720 composite amp IO390 Chip Amps 111 30th January 2019 01:47 PM
Composite amplifier with Class-D b_force Class D 15 17th August 2017 03:42 AM
V.2012 PRO. Composite Audio amplifier waso Solid State 22 17th February 2015 03:32 PM
Composite amplifier in class A Shaq888 Headphone Systems 0 5th May 2013 12:13 PM
Copyright ©1999-2019 diyAudio
