Hi , i finished one TDA7293 stereo amp.
I have Fostex Fe206en with 96db efficiency speakers.
One channel do some AC noise, i do not know if the 96db is the responsable, or if some is wrong in these channel.
I look at the circuit 100 times and I do not see anything wrong.
Can be the poor insulation between the transistor and the heatsink?
Santiago.
Santiago.
Usually wiring layout problems.
Have you used star grounding ?
Do you use a single earth in your system ?
Transformers next to audio wires ?
Unscreened input wires ?
tomorrow I will look at those details
- Chip Amps
- TDA7293 AC noise
