80-100W Class A or AB 24V amp existing ?
Old 17th February 2019, 11:22 AM   #11
FauxFrench is offline FauxFrench  France
Hi Tanguy,
I included two links in posting #4. The first is to a TDA7498E board that is foreseen for modification into PBTL (mono). This thread describes the modification: 7498E BTL Mode Question
The second link is to a TAS5630 based mono amplifier that is stated to handle 20Vdc-50Vdc.
Perform searches in Google including "diyaudio" if you want to find your way around in this forum.
Old 17th February 2019, 11:25 AM   #12
Yatsushiro is offline Yatsushiro  France
Totally OT, but I couldn't let this pass. FF, you have a way with words, whether technical or otherwise:
Originally Posted by FauxFrench View Post
One small detail - “twitter" is where energetic politicians tell the world about their talents...
Unfortunately the world now accepts and celebrates politicians mostly talking, rather than doing.
Old 17th February 2019, 06:57 PM   #13
TanguyClt is offline TanguyClt  France
You proposed me the TAS5630 DC20 50 v amp,
My bad I didn't see that the output power (600W) was given for 2 Ohms speakers, however I think that even with 36V the output will be higher than 100W for 8 Ohms, witch is too much for me.
Endeed they predict 200W for 8 Ohm with 50V DC so if we divide by 2 it will be 100W with 8 Ohm for 25V DC, so I will be at the limit of my speakers with only the minimum I want to get.
Plus, if I choose this one I will have to deliver a lot of intensity, they endeed said that "the proposed range is the best 24-45V, current 6A or more (the bigger the better)",it is really too much form my battery, even 3A would be too much.
Old 17th February 2019, 08:33 PM   #14
tomchr is offline tomchr  Canada
tomchr's Avatar
Another question to ask is: Why on earth do you need 80-100 W from a boombox? How large batteries are you willing to carry? Or how short runtime are you willing to accept?
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD. HP-1: 3W/20Ω, -130dB THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 17th February 2019, 08:47 PM   #15
Endeed it is a bit excessive, I wanted the greater sound possible no matter what the size of the boombox had to take. I came with these speakers :
-Visaton TW 6 NG, 8 ohm
-FaitalPRO 3FE22
-Monacor SPH-210
I wanted to do it even if I knew that the autonomy was low (bc remember that I will mostly use it on a fix place). My batterry is 2 packs in parallele of 6 18650 li-ion in series.
Actually I expect arround 3 hours as runtime.
Old 17th February 2019, 11:12 PM   #16
Hi Tanguy,
It may not be what you want. Just remember what I wrote before - any BTL coupled class D amplifier gives the same output power with the same supply voltage. Thus, also this amplifier gives 80W in 8 Ohm with 36V supply and 35W i 8 Ohm with 24V supply. The change in output power is not proportional to the supply voltage, it increases with the square of the supply voltage (double supply voltage -> 4 times the output power).
80-100W Class A or AB 24V amp existing ?Hide this!Advertise here!
I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem. Buckeye Solid State 89 7th December 2018 07:11 PM
100W Class AB amp badboy6120 Solid State 81 31st October 2017 05:32 PM
How to improve an existing SMPS to use it with class D amplifiers snake69fast Power Supplies 19 4th March 2016 05:27 PM
TDA7498 100W+100W Class D Amplifier comasus Class D 1 18th November 2015 09:05 PM
~ 50 WPC Class A Kit for existing Trafos? briansz Solid State 9 11th October 2011 09:54 AM
Copyright ©1999-2019 diyAudio
