TDA7293 IC
TDA7293 IC
Old 12th February 2019, 03:13 PM   #21
UltimateX86 is online now UltimateX86  France
TDA7293 IC
Why not using transistor like LINN CHARKA ?
https://static.qobuz.com/info/IMG/jp...ificateurs.jpg
GB2405275A - A discrete transistor boost amplifier for an audio driver IC, wherein the boost amplifier is automatically activated at high output levels
- Google Patents
linn abandoned the parallel to use transistors
www.circlotron.audio
Old 12th February 2019, 03:27 PM   #22
TDA7293 IC
HD photo : Mao Audiophile Modifications: A Linn Klimax Chakra 500 Twin rescued from the last flood
Old 12th February 2019, 10:21 PM   #23
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by Kay Pirinha View Post
Daniel, is it possible to combine the »modular« approach with the »economic« approach in the TDA7293 datasheet? That means paralleling the output stages of two or more chips and arrange them in a class g/h (whatever it may be...) environment? Best regards!
I didn't find out. See the arrangement with 1000uF connected near small signal portion of the amp? Large signal support on a board that ought to be treated like small signal, says that it is a subwoofer amplifier... and I lost interest directly. Today, we use Class D for subwoofers, especially NXP's Class D (after you put on a real input circuit including 470R series to each input to lower crosstalk).
However, it was interesting to see the possibility of TDA7293 chips in slave mode working at up to +-50vdc (32+32vac transformer). So, a parallel output tube hybrid looks promising. Or, if you happen to have a driver chip handy. I haven't tested at that voltage, but TDA7293 in slave mode looks like bargain priced audio output fets.
Old 22nd February 2019, 02:09 PM   #24
santitrucco is offline santitrucco  Argentina
Friennnddsssss !!!!
I have a new module with TDA7293.
I have a little hum 60hz, in ONE channel..
Only little and only in one channel.
Whyyyyy ?
And i have 0.014 ac in these channel.
File Type: png 52605912_2464419343605583_8512088335529803776_n.png (737.8 KB, 118 views)
Old 22nd February 2019, 02:13 PM   #25
Is not in one chassis , only in a wooden board.
could be this ?
would it serve a cable from ground on pcb to chassis or main transformer ?
Old 22nd February 2019, 07:47 PM   #26
Old 22nd February 2019, 08:04 PM   #27
Please
Old 22nd February 2019, 10:55 PM   #28
PRR is online now PRR  United States
PRR's Avatar
> only in a wooden board. could be this ?
Yes.
Old 22nd February 2019, 11:06 PM   #29
I will Try
Old 23rd February 2019, 01:10 AM   #30
the 60hz are still in one channel
TDA7293 ICHide this!Advertise here!
TDA7294 BTL PCB Einric Chip Amps 8 7th April 2012 07:44 AM
TDA7294 in BTL Einric Chip Amps 4 26th February 2011 02:38 PM
TDA7294 in BTL ruferto Chip Amps 6 26th January 2011 12:19 PM
Should I TDA7294 p2p pra3718 Chip Amps 1 16th December 2009 03:14 PM
Need help on tda7294 amp Fossil Chip Amps 6 20th April 2005 02:53 PM
Copyright ©1999-2019 diyAudio
