Simple 14w (7w+7w) stereo amplifier layout
Old 11th January 2019, 04:01 AM   #1
22uf is offline 22uf  United Kingdom
Default Simple 14w (7w+7w) stereo amplifier layout
I have some speakers and in total they add up to 14w. I want to build a small portable stereo system, but Iím having trouble looking for a PCB transfer layout for a 14w stereo amp. It doesnít have to be 14w; 10w or whatever is fine too. I just need it to have a volume control, on-off, power in, and an led light. Any idea where I could find this? I have looked everywhere.
I donít need anything complicated, just a simple stereo amplifier up to 14w/7w+7w.
Old 11th January 2019, 05:59 AM   #2
Bruce@bluff is offline Bruce@bluff  South Africa
You best bet would be chip based. I would go for the STA540. I have attached the datasheet. You cant get more simple than that
Old 11th January 2019, 06:19 AM   #3
Well yes, I totally agree. Is there a pcb layout anywhere for something like this?
Old 11th January 2019, 06:30 AM   #4
Usually there is one in the datasheet try chip amp guys on the forum. If you are a beginner I would suggest building it on a stripboard first
Old 11th January 2019, 09:18 AM   #5
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
There is TDA7375A amplifier kits off ebay going for 8 US$ shipped worldwide and the pcb and componenet layout is available in the datasheet. I have built myself one on a perfboard, works alright.
"Immer wenn du denkst es geht nicht mehr, kommt irgendwo ein Lichtlein her."
Old 11th January 2019, 01:44 PM   #6
kokoriantz is offline kokoriantz  Lebanon
TDA7297 is very famous, if your speaker is 8 ohms it is the best 2x18w. Look on YouTube several recordings demonstrated. On Aliexpress you'll find from 2$ all mounted.
Old 11th January 2019, 03:57 PM   #7
I mean something like this image, the bottom right.
Old 11th January 2019, 07:51 PM   #8
FauxFrench is offline FauxFrench  France
I use "Veroboard" as shown to the left. It leaves you the flexibility to implement almost any circuit with "through hole" components. Use of SMD components is very difficult.
If you are not comfortable with that kind of boards consider bying a "kit". Such a kit has a real PCB and all the components delivered with it. Bying a PCB and all the components yourself is just more work.
Examples:
TDA7377 amplifier board Power Amplifier 2.1 DIY kit 3 Channel Sound Audio AMP Board 12 18V DC-in Printer Parts from Computer & Office on Aliexpress.com | Alibaba Group
TDA7297 amplifier board spare parts dc 12v grade 2.0 dual audio encoding 15w electronic diy kit-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
TDA7297 is really value for money. TDA7377 is an improved TDA7297. STA540 is great - I just didn't find a kit. TDA7850 is superb. There are many high performance chips for 12V-22V single supply. It is just to find the right DIY kit.
Old 13th January 2019, 04:25 PM   #9
Examples:
Thanks, I think this is the best way!
Old 14th January 2019, 02:00 AM   #10
tomchr is offline tomchr  Canada
tomchr's Avatar
You could run an LM3886 from Ī20 V. That'd give you a touch over 15 W into 8 Ω.
My LM3886DR would fit the bill.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD. HP-1: 3W/20Ω, -130dB THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Simple 14w (7w+7w) stereo amplifier layoutHide this!Advertise here!
300w power stereo amplifier with pcb layout wattaniya Solid State 15 24th March 2015 02:54 PM
Design simple Stereo Audio Amplifier az00025 Construction Tips 13 2nd December 2011 06:22 PM
Copyright ©1999-2019 diyAudio
