Ugh, I see Corrosive Black Gunk. What's that doing there anyway? It may or may not be part of the problem, but should be scraped off either way. As a bonus, you could then see where those traces going to the diodes are coming from.
Through-hole soldering looks a bit spotty, too... some pins seem to have a lot of solder on them, some too little.
Seeing four diodes together makes me wonder if its part of a bridge rectifier. You would have to just look at how they connect together.
Thank you Mooly, I have looked at the tracks but I do not think it is a bridge rectifier, I think it's a zener diode but I can not find the schema of the preamp, I only found the schema of the game amp on a diyaudio post.
Thank you sgrossklass, I do not know yet if an integrated circuit is involved but the diode D3 is short circuit, even unwelded.
Options would be to just fit 'something' and see what happens.
Are any rails to the opamps missing ? If a pos or neg rail is missing then see what happens when you fit say a 5v1 or a 12v Zener.
Could it be a 'transorb' type device fitted across a rail as some kind of over voltage or spike protection. If so then run it up with it removed.
You need to be creative when you can't get circuit details.
Check 12 pin IC’s.
U2,3 &4 look rough. Is that dum dum stuck to the cases?
Hello,
I have a problem with a Proel amp wd12a, on the preamp there is a diode "D3" which is grilled and I do not know what it is.
Someone would be kind to help me or if someone would have the schematic, please?
Thank you beforehand.
- Chip Amps
- Proel amp wd12a
