Modulus-186 for a highly sensitive speaker
Old 27th January 2019, 05:09 PM   #21
tomchr is offline tomchr  Canada
tomchr's Avatar
Fantastic! Good to hear of your progress. I'm looking forward to the pictures.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD. HP-1: 3W/20Ω, -130dB THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 3rd February 2019, 06:45 PM   #22
jazzlampe is offline jazzlampe  Germany
jazzlampe's Avatar
Today I had some fun testing the power supplies and protections circuit. All is working fine. Tom's documentation helped a lot. I'm not that experienced so there is some uncertainty every now and then, but that concerns more the case and metal works to come.
I did not popupate the IEC connectors and switches since mains will be connected via Neutrik PowerCon and switched on via rotary switches on the front.
Now I wait for the MiniDissipante, knobs an switches to be delivered. This will be fun.
Old 3rd February 2019, 07:35 PM   #23
jazzlampe's Avatar
Promised to post pictures, didn't I?
Old 3rd February 2019, 10:11 PM   #24
tomchr's Avatar
Very cool. It's always good to see progress. Thanks for posting.
Tom
Old 10th February 2019, 01:53 PM   #25
jazzlampe's Avatar
Default Progress
Today I put my layout to the test. Rather tight around the power supplies, I must say. Al least for my chunky fingers...
Mains power will be led straight from the blue PowerCon connector under the guardian PCB to the front through shielded cable. From there I can keep all the wires as short as possible.
I also made a mockup panel design with an old b/w laser printer and red feltpen. So far I'm satisfied with the outcome.
Old 10th February 2019, 06:19 PM   #26
tomchr's Avatar
It looks like a tight squeeze for the power on LED outputs on the SMPS-86 boards. You can get a vertical version of the connector if needed. Mouser P/N: 571-284517-2 would be an example. Otherwise nice layout.
Which of the Mini Dissipante chassis is this? 2U x 300 x 330mm?
Tom
Old 10th February 2019, 09:00 PM   #27
jazzlampe's Avatar
The image shows the PowerCon and the speaker protection not in the right position. There will be enough space (at least 2cm) between the parts.
Yes, it's the 330x300. A fine case. The covers did not match but modushop will take care of that. They are very kind people.
Old 10th February 2019, 11:11 PM   #28
chrisb is offline chrisb
Whence the rather tasty knurled knobs?
Retired from active DIY
Old 11th February 2019, 06:19 AM   #29
jazzlampe's Avatar
I got them at audiophonics (France). I was glad I found them but there is light and shadow: Like most of the chinese stuff the real thing doesn't look as neat as in the pictures. And they saved on the grub screws.
Old 11th February 2019, 06:59 AM   #30
tomchr's Avatar
I seem to recall buying similar knobs at VT4C.
Tom
Modulus-186 for a highly sensitive speakerHide this!Advertise here!
Searching for a sensitive 12" fullrange speaker Bassjunk Full Range 20 13th October 2015 06:38 AM
extremely sensitive speaker for xtal radio? Bigun Full Range 18 19th March 2013 11:41 PM
FS: Highly required Gigawork DAC Atlplasma Swap Meet 3 18th April 2011 03:02 AM
FS: Zhaolu 2.5C Highly Modded BobM Swap Meet 3 10th December 2009 10:20 PM
Highly rated 4" jmar Full Range 17 24th October 2009 05:54 PM
Copyright ©1999-2019 diyAudio
