NE5532 for LM3886..need help!!
Old 30th November 2018, 02:13 PM   #11
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Originally Posted by nirupambhowmick View Post
But this circuit works well though not hi-fi type. Do you have any better design? Regards.
The basic design is fine, just feed it well, and if possible add a buffer ahead .
Or a gain stage, say 5X or 10X gain so system is more sensitive and you can, say, drive it properly from a Phone output
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 30th November 2018, 06:53 PM   #12
nirupambhowmick is offline nirupambhowmick  India
Originally Posted by anti View Post
If I were you I would replace the both 1K resistors with 100 Ohm 1 Watt types, replace the both 100uF caps with the largest value that fit onto the board (something in the 220-470uF range, 16V) and add two 12V 1 or 2W zener diodes across the both caps (something like the ZY12 or the like), which can be soldered on the bottom side of a board. In effect making a passively stabilized +/- 12V supply for the opamps.
Alright... i'll add Zeners at power supply board.
thnks for your suggestion.
Actually this circuit works well with phone output...Seriously.
No problem so far...but thank u for the advice
Regards.
i think it is better to use general voltage regulator(7812/912) than shunt regulator. what do you think? i mean for low noise, ripple etc.
Old 8th December 2018, 02:45 AM   #13
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Strange old circuit.
It says its a pre amplifier but appears to have no gain.
Its just a buffer and tone control with volume control on output.
It buffers then puts 1k and pot in series with the output.
Sort of defeats the object of the buffer.
PCBCAD51 download or CDROM 2019 version out now http://www.murtonpikesystems.co.uk
Old 8th December 2018, 11:16 AM   #14
anti is offline anti  Slovakia
Of course it would be "better" to use 7812/7912 regs .... but can you do it right on the board that you presumably already have?
A 2-watt zener like ZY12 can really save the day in a situation like that.
Old 9th December 2018, 07:49 PM   #15
i know that i'll put those reg. at main supply board.
Old 9th December 2018, 07:53 PM   #16
then what should i do?
NE5532 for LM3886..need help!!Hide this!Advertise here!
NE5532..AN/AFE/N/D???? mprivitera1 Analog Line Level 24 13th October 2015 11:42 AM
LM3886 amp with NE5532 volume control board Bradford336 Power Supplies 4 23rd November 2012 01:51 AM
Pics of my new 4 way active filter and amplifier using NE5532 LM3886 and LM1876 aniruddha Chip Amps 10 18th April 2012 09:54 AM
lm3886 and 3 ne5532 done ramuengr Chip Amps 2 19th September 2010 02:55 PM
What about NE5532? rhavecilla Chip Amps 12 6th September 2007 04:05 PM
Copyright ©1999-2019 diyAudio
