Yet another LM3886 lacking bass thread.
Old Yesterday, 03:35 PM   #51
00940 is online now 00940  Belgium
00940's Avatar
The lm3886 has an internal protection system (more about it in this app note). This will limit the power delivered by a lm3886 into a load. It will mostly affect the low frequencies but not at a set frequency, it's an interaction between level, load, frequency and temperature.
Having the lm3886 properly heatsinked helps but, ultimately, the only workaround to drive low impedance/low sensitivity speakers are paralleled ICs.
All that is excessive is insignificant. Talleyrand
Old Yesterday, 03:42 PM   #52
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Rod Elliott has just issues with it's protection system
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old Yesterday, 03:55 PM   #53
anti is offline anti  Slovakia
It's a loosely similar effect as if you compressed the low frequencies only (f.e. sidechained a compressor with a lpf). Resulting in a "flattened" sound (i.e. not "round").
Imho a "loose muscle grip" on bass region describes the situation perfectly. Ymmv?
Old Yesterday, 04:22 PM   #54
00940's Avatar
Not really in my view. With most music and speakers, at normal (including loud) listening levels, it's not active or audible at all. When it kicks in, it has gross distortion (look at the waveforms in the app note).
Btw, this applies even to composite amps as the modxxx or the myref. It's quite different to the psrr issue which, otoh, is really helped by the composite amps higher open loop gain.
Old Yesterday, 06:50 PM   #55
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
Originally Posted by chrisb View Post
The “chip” itself is only part of the story. As anyone who’s heard or built any of Tom Chr’s Modulus series amps, the LM3886 does not inherently suffer from lack of bass.
+1
The LM3886 is both one of the most highly built, and most improperly built of all audio ICs. In a proper setup they are very good at what they do. Hearing TomCHRs Modulus amplifiers driving the Linkwitz LXMinis at Burning Amp fest this year was a very rewarding experience, and was probably one of the best solid state setups I have ever heard.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old Yesterday, 07:55 PM   #56
maty tinman is offline maty tinman  Spain
maty tinman's Avatar
Default Woofer of 8 Ohms
Originally Posted by Lingwendil View Post
+1
http://melp242.blogspot.com/2018/06/...pressions.html
I decided to look for an amplifier in a half-rack width body so I can fit it into my gear rack. The woofer driver of LXmini is rated for 8 Ohm impedance and "long term power handling" for 80 Watts.
The second—full range driver is 4 Ohm and requires less power. So I decided to look for a 4 channel amplifier rated for 100 Watts into 8 Ohms to have some headroom.
"Comment is free, but facts are sacred" - C. P. Scott
Old Yesterday, 11:52 PM   #57
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Originally Posted by maty tinman View Post
Talking about LM3886, this amp has two, one by channel:
ARCAM FMJ A19
Very bad LM3886 implementation I think.
But it sounds great so the numbers are just part of the story. The sonic presentation reminds me of my AKSA 55N+.
No longer DIY active
Yet another LM3886 lacking bass thread.Hide this!Advertise here!
Yamaha RX-V359 - Lacking bass. Looking for solutions. krafty Chip Amps 10 14th September 2016 07:15 PM
tda7923 linn lk140 bass lacking jocker Chip Amps 2 26th May 2015 07:56 PM
QED A240CD lacking bass. pastedavid Solid State 32 12th March 2015 08:13 AM
Lacking bass response after re-cap mustang guy Tubes / Valves 5 18th December 2013 01:34 PM
Zen headphone amplifier lacking in bass hansel Headphone Systems 13 2nd April 2006 09:18 AM
