TDA2008 and TDA2003: same PCB ?
Old 18th October 2018, 08:50 PM   #11
Peters8 is offline Peters8  Italy
Thank MJF!
I've already read the TDA2008 datasheet, but, since I'm a newbie, I've still have some dubt.
For this reason I've asked for your help.
Best regards
Old 18th October 2018, 09:56 PM   #12
meik65 is offline meik65  Germany
as you can read in the datasheet the frequency response of the circuits is 40 Hz to 15 kHz
which isn`t up to date, they were designed for Lo-Fi use in cars or cheap cassette recorders. The output capacitor together with the 4 or 8 Ohm speaker are building a high pass filter to reproduce a frequency of 40Hz you need a capacitor of 950uF with a 4 Ohm speaker or a cap of 500 uF with a 8 Ohm speaker. That means a 1.000uF as in the datasheet will do the job.To have a little headroom and prevent aging issues you can use 2.200uF but 8.200uF doesn't make sense the circuits aren't capable of reproducing this low frequency on the output. I fyou only want to play around with the board using the TDAs is OK, but there are much better integrated amps to buy for little money , i.e. LM3886 or TDA7497 both classic AB amps and not class D.
Old 19th October 2018, 03:29 AM   #13
Thank you Meik65!
Your help is very precious to me!
TDA2008 and TDA2003: same PCB ?Hide this!Advertise here!
TDA2003 PLEASE HELP Hellboy5562 Chip Amps 7 12th April 2014 09:51 AM
Upgrade for a TDA2003 giralfino Chip Amps 6 4th April 2010 06:43 PM
Help with TDA2003 amp Tahmid Solid State 7 14th July 2008 06:21 PM
Help with Cana-Kit using TDA2003 noob for now Chip Amps 1 8th December 2005 10:08 AM
Copyright ©1999-2019 diyAudio
