TDA2050 Kit Strange Behaviour
Old 21st September 2018, 08:13 AM   #1
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
Default TDA2050 Kit Strange Behaviour
I recently completed a pair of TDA2050 kits to make a desktop amp pretty much one of these:
Tda2050 25W DIY mono brand AB digital amplifier audio sound board kit parts have a fever-in Power Tool Accessories from Tools on Aliexpress.com | Alibaba Group
The amplifier runs single supply 24v (Kit recommends max 25v) and I have paired this with a generic bluetooth module with a 10k Log pot between the BT output and Amp input.
I noticed that the sound quality declines at about 1/3 of the volume range so I put the output on the oscilloscope.
Amp clips at 7.7v into 8 ohms.
What is strange is that as I turn the potentiometer, up to 1.4v is a smooth increase in amplitude. Then 1.4-1.6v the amp oscillates and the output stagnates. When the output gets to 4.5v, the increase is exponential up to 7.7v where it clips. (See attached diagram).
The behaviour is the same on both channels but the RH oscillates worse - that side has severe oscillation (always around 1.4-1.6Vout) for the first 2 or 3 times I turn the volume knob after a power on. It then stabilises to the previously described behaviour.
Firstly are there any suggestions as to how I can tame this behaviour? I don't think it is normal..
Secondly, is about 7.7v peak out about right for 24v supply on an 8 ohm load? Is 25W into 4 ohm typical Chinese seller optimism? I've confused myself going round in circles trying to do the simple calculation.
Cheers!
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Preamp | : VSQC Phunk Style, Retro 50W | : Apex AX-14 | SHPA | TGM-10 | TDA7265 (Last in line)...maybe
Old 21st September 2018, 08:40 AM   #2
FauxFrench is offline FauxFrench  France
For the 25W in 4 Ohm the analysis is rather simple: You measure a clipping voltage of 7.7V in 8 Ohm with 24V supply. That is 5.5Vrms. Assuming the clipping voltage would also be 7.7V in 4 Ohm (probably it will be less), the output power is (5.5x5.5)/4=7.5W. So, 25W - no way.
On the oscillation:
It may relate to class AB amplifiers having a varying loop-gain depending on where in the output range the output momentarily is. Said in a different way, the more the amplifier leaves its idle voltage level (in your case probably 12V measured from the negative supply rail), the more loop-gain. This increase in loop-gain can cause the amplifier to oscillate. I have myself noticed a similar phenomenon with an LM1875 (pretty similar to TDA2050). What I noticed on my oscilloscope was one sine-wave half-period suddenly "clipping" by this self-oscillation that would die out again at lower levels. I also had a non-linear output characteristic like you describe.
Good decoupling will always be better but cannot necessarily stop such oscillation.
Try removing the speaker. Do you have the same oscillation problems? If yes, do you see the oscillation on the positive supply pin (pin 5) of the TDA2050? What is the self-oscillation frequency?
Old 21st September 2018, 10:09 AM   #3
avtech23's Avatar
Thanks for confirming the figures, Faux. I suspected they were dodgy figures as the datasheet has these at 25W with a +/-25v supply if I remember correctly. So I figured Single supply of 24v would surely be at least half of that quoted figure.
The measurements were taken with an 8 ohm dummy load, no speaker attached. I'll try to make those measurements later but the amp is fully cased up at the mo.
I saw a forum post that said that they had similar experience and needed to add resistance (presumably to the ground of the volume control circuit) but it was very vague. I just wonder if the oscillation has anything to do with the use of the 10k pot affecting the circuit?
Old 21st September 2018, 10:25 AM   #4
Half the supply voltage (total) means roughly one quarter power.
No load is an interesting test because the load current is an important factor in changing loop-gain: My LM1875 behaves well without load or even with 16 Ohm. 8 Ohm starts the problems and 4 Ohm is worse.
In case of self-oscillation, I start with a check for intrinsic instability. Input shorted by 1KOhm and no load - does it oscillate? Then, load on but input still shorted - does it oscillate?
If I pass the two first steps, I go on with the operational instability: Sine-wave input signal but no load - does it oscillate in certain areas of operation? Then, varying loads and sine-wave at the input - does it show temporary instability?
My experience is that such temporary instability is very difficult to fight because it is inherent in the chip.
The 10K potentiometer I do not see as a first worry.
Old 21st September 2018, 11:30 AM   #5
Bone is offline Bone  United Kingdom
The trouble with buying stuff from China is there are a lot of fake ICs being sold.
Old 21st September 2018, 12:02 PM   #6
The "fake" ICs is an issued that has been debated a lot on this forum. Most likely "fake" means chips that were discarded in regular legal production due to some non-compliance with specs. The stability issue may be one such reason for rejection. But, if more behave the same it may hint a general problem.
Old 21st September 2018, 02:11 PM   #7
avtech23's Avatar
Very true. Unfortunately it seems to be the price we pay for paying a small price..
I honestly wasn't expecting very much with this kit being it was so cheap, but I expected a bit more than 8w when it is advertised as 25w.
Old 21st September 2018, 02:25 PM   #8
avtech23's Avatar
So I've played around with the amp, injecting 1khz 2v and trying different configurations.
The stability is better when using 4 ohm speakers - I think that is the way to go. It sounds noticeably better on the 4 ohm drivers than the 8 ohm JVCs. I get a little over 8v pk-pk out at clipping so you were pretty spot on there, Faux.
The strange pause in the amplitude increase as I turn the volume up is still there but I guess I'll chalk that one up as a 'design feature'.
This one was a side project and my first proper dabble in chip amps so I won't fuss over it too much, but I'll probably start looking for another chip amp to build. Any recommendations?
Old 21st September 2018, 04:34 PM   #9
The majority of Chinese sellers on the Internet are traders without particular technical knowledge. You may look at the range of products they offer to be convinced. They try to make a modest living from re-selling products at very low price.
We are used to much higher prices in return for more precise information. Perhaps your TDA2050 board is not limited to 25V (depends mainly on the voltage rating of the capacitors) and can output more power? The information available at sale is ambiguous. Perhaps not due to bad faith but rather lack of knowledge.
I buy “DIY experiences” from China and I spend no more than I won't regret if it will be a failure in the end. In average, my experiences are very good (for the price) but often I find details I like to improve. I am actually happy that nowhere can they supply a perfect product by highly competent people at the price I buy in China. It would tell me that my competitiveness is even less than I already fear.
Imagine your board was manufactured and sold in Australia and the resulting price. You can find high quality audio modules from Oceania, US/CA or EU but at very different prices. Even from China with a significantly higher price-tag. Where you buy is your choice because you can afford to buy at higher prices, many can't.
Old 21st September 2018, 05:02 PM   #10
It depends fully on what you want to achieve. Super high quality to enjoy for many years ahead, try Tom's "Neurochrome". Western price level but worth every Canadian Dollar you pay. Class AB.
A board or a ready-made amplifier in a box? Perhaps you should try class D this time. A very different design I would have sworn decades ago could sound good. But I have to give in, they sound as good as class AB.
Power level? Do not exaggerate your needs. Many make powerful amplifiers (they actually don't need) just to realize that the power supply needed to supply that kind of power costs as much as the amplifiers.
A board that does not need much "pimping" is based on TDA7498E. Close to 100W for around 25 US$.
I am a concept guy who likes to experiment with different rather cheap amplifier boards and to understand their strengths and weaknesses. My boards are used a couple of months in a lifetime.
I still have a fascination for Tripath amplifier boards though they stopped official production back in 2007 (bankruptcy) but still have an excellent mid-range sound.
"chermann" is specialist in TPA325X boards that are generally of high quality but not without some flaws. Read about his findings in the two threads where he is very active.
The cheap fun most DIYs have been through is a TPA3116 board. From $5 and upwards. You get the 2X30W they state or even more. Not the final amplifier for your lifetime but a lot of fun.
TDA2050 Kit Strange BehaviourHide this!Advertise here!
Strange behaviour of my F5 permaneder Pass Labs 29 20th May 2013 03:10 PM
Strange XO behaviour tinitus Multi-Way 10 7th March 2009 03:50 AM
Strange 45 behaviour - help hal3101 Tubes / Valves 2 9th November 2007 09:38 AM
Strange vol. pot behaviour ?! Cradle22 Solid State 11 28th January 2004 09:08 PM
Strange amp behaviour.... 5th element Solid State 13 6th July 2003 05:54 PM
