Lower chipamp distortion through PCB routing
Old 7th August 2018, 09:50 PM   #51
alexcp is offline alexcp  United States
alexcp's Avatar
Thank you all for the recommended reading.
So far, I read the TI app note recommended by KSTR in post #46 above. I found it very compact and accessible.
As an exercise, I designed, simulated, and built a composite amp with a gain of 21 with two halves of an TL082 - see attachments. As predicted, it oscillated without compensation, and properly compensated, it demonstrated very different distortion behavior compared to a single half of the TL082. The measurements below were taken at approx 8Vrms output level, just below clipping.
Old 24th August 2018, 04:32 PM   #52
miklos is offline miklos  Hungary
miklos's Avatar
Hi Alex,
I got my boards, they're nice
Thanks, Miklos
miklos
Lower chipamp distortion through PCB routingHide this!Advertise here!
Does lower Qes, Qms and Qts speaker will produce lower distortion ? dipankar862 Multi-Way 110 28th May 2017 09:40 PM
Lower load resistance for lower distortion (6L6 PP) mrneedle Tubes / Valves 2 26th March 2016 03:22 PM
Lower efficiency = more distortion? chris661 Subwoofers 27 16th March 2014 06:11 PM
does lower B+ cause scratchy distortion? PRNDL Tubes / Valves 0 20th June 2008 11:13 PM
Excel W12 lower distortion than W15?!? capslock Multi-Way 0 24th February 2004 11:34 AM
