Critique my PCB! Yet another parallel LM3886
Old 10th June 2018, 03:31 PM   #11
abza is offline abza  South Africa
abza's Avatar
Thanks @00940 - great reference.
Okay, I'm starting from scratch. Before I get too carried away, I just wanted to get an opinion on the following pour layout, using suggestions above. The power pours are now much larger and consistent in thickness, the outputs are now chunky instead of individual traces. The entire ground plane (on the bottom) has been flooded, with some separation near the input section as per @tomchr's feedback in this thread.
I've not routed anything else except for the two output traces from the LM3886es to the output pours - attached are just the pours as a work in progress, the text/component placement is still a little messy. But does this look good from a general grounding and pour perspective?
Old 10th June 2018, 05:16 PM   #12
asuslover is offline asuslover  Romania
I see that you insist in having v+ in one side and v- in the other side of the board, that means you'll have unnecessary longer cables from the power supply to the amplifier board , and I think would not look so neat. Am I the only one who's not a big fan of diagonal components?
Old 10th June 2018, 05:50 PM   #13
abza's Avatar
@asuslover - I literally just finished an option where the power connectors are grouped together
Attached - still keen to see whether either of these two versions are better in terms of grounding and pour placement.
Old 10th June 2018, 07:38 PM   #14
00940 is offline 00940  Belgium
00940's Avatar
You might have a look at this too: DIY BPA300 6x LM3886 300W audio Amplifier
All that is excessive is insignificant. Talleyrand
Old 10th June 2018, 08:22 PM   #15
Looks much better, I can't see how pins no 3 for the ic s are connected.I would connect them to ra6/ra4 on the bottom of the board so you can leave V+ Copper pour as wide is possible.
Old 10th June 2018, 08:57 PM   #16
Mark Whitney is online now Mark Whitney  Netherlands
Mark Whitney's Avatar
The output ground is missing in both the schematic and PCB.
Regards Mark.
Old 11th June 2018, 06:43 AM   #17
abza's Avatar
As mentioned the example images are pretty much just the pours for now, but will keep this in mind. Thanks for the feedback! Will forge ahead with this general layout.
@Mark - this is intended for use in a balanced/parallel setup - another identical board is handling (what would be) the output ground - see here.
Old 11th June 2018, 07:33 PM   #18
Those halves of your amp should be working individually , I would focus on designing an fully working amp (output ground is a must) and then bridge 2 of them.
This is how Tom is suggesting this to be done.
Old 11th June 2018, 09:16 PM   #19
abza's Avatar
Okay, what I'm calling version "4", attached.
Lots has changed, used the ground layout settled on with @asuslover - I'm preferring the grouping of the power pins as well, which has been consolidated into a fat Molex style power connector.
Ballast resistors (0.1R) added as well.
Most of the heavy-duty connections are now handled by pours, with a few traces on the top (and a couple on the bottom) handling signal paths.
Things to do: add an output ground, add mounting holes.
Is this looking any better? Worse? Hit me
Old 11th June 2018, 09:16 PM   #20
abza's Avatar
Beat me to it! This is on the to-do list for v5 Thanks!
Critique my PCB! Yet another parallel LM3886Hide this!Advertise here!
HELP with LM3886 X3 in parallel. Aguilabrava Chip Amps 45 7th November 2016 07:54 AM
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 24 21st October 2013 05:50 PM
LM3886 x 2 in parallel jmar Chip Amps 46 24th October 2009 03:53 PM
LM3886 parallel PCB's jmillerdoc Chip Amps 0 27th May 2009 08:26 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
