Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
#221 |
I built it for a friend 18 months ago, I think it is excellent.
I have the Gerber files available on my hobby website (with links to this page) and they have been accessed over 1000 times, so I would say there are probably a fair few completed amps out there. Very few people come to this page asking for help which could suggest they haven't had any real problems with it. It's relatively cheap to build, why not just send the files off and give it a go? |
#222 |
What is the largest AWG stranded copper wires that can reasonably fit in the PCB terminal through-holes?
#223 |
AWG18 should fit without problem, AWG16 will be too tight. The drill hole is a 1.3mm one.
All that is excessive is insignificant. Talleyrand |
#224 | |
I was considering whether to solder wires directly to the board or use a terminal block. At the end of the day I suppose anything other than soldering (at least for my application) would just be a waste of time and money, as 18 AWG is more than enough for how much power I need out of these. |
#225 |
#226 |
Anyone can please list me values of components for PSU and DC protect?
#227 |
for the DC protect: An open source layout for LM3886?
for the PSU: ok, a bom was here: An open source layout for LM3886? but it's not fully correct. Caps and resistors should be fine but the final version uses the bridges mentioned in post 63. The heatsink should rather be the Ohmite RA-T2X-38E
All that is excessive is insignificant. Talleyrand Last edited by 00940; 8th November 2020 at 06:13 PM. |
#228 |
I just realised I only posted my build to the main gallery thread & never actually contributed back to this thread. I finally finished it back in May this year, after starting in 2018.
It is a 3 channel build for a 2.1 setup, with two of the boards bridged via a Vigortronix VTX-101-007 audio transformer. There is a lot of empty space in the enclosure because I originally intended to house an active crossover & its power supply in the same enclosure, but in the end I stuck with my separate dbx crossover. I know my hand wound coils are bad, but I have to leave myself something to improve on next time. I also built a 3U rack from some cheap plywood. I am very happy with the results. I used my last gainclone for 8+ years & I now intend to use this one for 8+ more. Last edited by lost eden; 8th November 2020 at 07:14 PM. |
#229 | |
![]() Quote:
I'm planning on printing the PCB's and make (another) an amp for myself So... I have some questions: Are these gerber the final version? Anything I should be worried about? Do you have a BOM's list? (found them, thanks)I don't want to mess it up And thank you so much for all that work, it looks amazing by the way ![]() Last edited by eisp4nzer; 26th November 2020 at 07:19 PM. |
#230 | |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
[Open source] TINA The total open source Audiophile Player based on Beaglebone Black | DragonWar | PC Based | 7 | 18th December 2016 03:31 PM |
Ultimate Open Source XMOS USB-I2S: The source to end all sources. | krfkeith | Digital Source | 4 | 14th June 2013 04:54 PM |
Volume / Source selector - open source project ? | AuroraB | Analog Line Level | 22 | 22nd September 2012 03:21 PM |
Open call for suggestions on Open Source DIY Audio Design | gfergy | Everything Else | 1 | 15th April 2007 08:33 AM |
Open Source, Open Architecture! | zenmasterbrian | Digital Source | 185 | 23rd February 2007 11:35 PM |
New To Site? | Need Help? |
