Selector switch
Selector switch
Selector switch Please consider donating to help us continue to serve you.
Old 4th April 2018, 09:08 PM   #1
gimpchop is offline gimpchop
Default Selector switch
Hi I'm trying to add a selector switch to control inputs i.e tape CD mp3 ECT but I don't know what type of switch to order. I know I want a rotory style switch but as for how many poles I need. Thanks
Old 4th April 2018, 09:17 PM   #2
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Hi, poles are separate switches, ie, stereo you'll need 2 pole, then ways is the number of sources you want to switch
Old 4th April 2018, 09:17 PM   #3
rayma is offline rayma  United States
what type of switch to order. I want a rotory style switch but as for how many poles I need.
You need an X position 2 deck rotary switch for stereo, where X is the number of different sources.
Tape, CD, and mp3 would be 3 sources, so that's a 3 position 2 deck rotary switch.
Each deck is for one channel. Some switches however can have both channels on the same, single deck.
Of course you can get a switch with more positions than you need, and ground the extras.
Old 5th April 2018, 12:46 AM   #4
MAAC0 is offline MAAC0  Portugal
This one perhaps ? It Switches Stereo since it has 3 poles.
Third pole You can use to switch source Led indicators.
Hi-Rel Adjustable Rotary Switch | 3 Pole 2-4 Position | 10WA366
Old 5th April 2018, 02:53 AM   #5
tomchr is offline tomchr  Canada
tomchr's Avatar
You'll need a two-pole switch with as many positions as you have sources. Note that some switches, like the Lorlin (EU) or C&K (North America) switches have stops that are movable. In those cases you can buy a two-pole, four position (or four throw; 2P4T) switch and move the stop one position and get a 2P3T switch out of it.
Ideally, the switch should be break-before-make, i.e. it breaks the connection with source #N before making the connection with source N+1 when you rotate the switch. Most switches are break-before-make.
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 5th April 2018, 09:22 AM   #6
Great thanks for all the awnsers most helpfull.
Old 5th April 2018, 09:34 AM   #7
Mooly's Avatar
Selector switch
Try these:
http://cpc.farnell.com/lorlin/ck1030...ric/dp/SW04137
Free delivery on orders over 5. Just type Lorlin into the search box and you will see all the options. A 3 pole 4 way would also allow you to add an LED indicator to show which source was selected.
Old 7th April 2018, 03:43 AM   #8
Panelhead is offline Panelhead
I like using a four pole for stereo. Parallel two poles for each channel. Less chance of a dirty contact. Plus less noise in theory.
Cheapest is bestest
Old 7th April 2018, 04:35 AM   #9
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
Selector switch
I like a single pole switch energizing a two (or more) pole relay.
"In the world of commerce and finance it is thought quite remarkable if a man is both clever and honest." -- Demosthenes
Selector switchHide this!Advertise here!
Selector Switch Enochrome Parts 15 15th April 2017 11:17 PM
Amp Selector Switch - multiple amps, rotary switch peraho Analog Line Level 3 1st April 2015 10:24 PM
Selector Switch for BOZ rtate Pass Labs 7 21st December 2009 12:42 PM
Selector switch on a T-amp? triodesteve Class D 1 31st December 2005 06:04 AM
pre-amp selector switch bonz Solid State 2 21st November 2005 05:37 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
