Troubleshooting low frequency humming in PC speaker set
Old 6th January 2018, 10:54 PM   #1
Floris89 is offline Floris89
Default Troubleshooting low frequency humming in PC speaker set
My Logitech Z-2300 unit suffers from an audible low frequency humming. My observations about the humming are as follows:
  • The humming comes from both satellite speakers and the woofer speaker. Though I'd say the humming from the satellite speakers is slightly louder.
  • The humming is independent from the volume setting on the control remote
  • The humming is present with and without an audio source connected to the 3.5mm input
  • When disconnecting the satellite speakers and the woofer speaker, the humming is no longer audible. Though I can hear a similar humming (same pitch) originating from the toroidal power transformer, but it is much less audible.
  • The humming remains audible when only the woofer is connected (with satellite speakers not connected) and when only the satellites are connected (with woofer speaker not connected).
  • The humming was also present in my previous home.
Upon researching this issue on google, the most probable culprit would seem to be a ground loop. Note that the unit does not have a ground terminal (it uses a two terminal plug). I've disconnected all other appliances in the room and connected the speaker set directly to the wall socket, but the humming still persisted. Nevertheless I have been unable to exclude a ground loop as the cause of the humming. Can a ground loop be a problem considering the device is not grounded to the mains? Perhaps the issue lies with the grounding inside the unit? Would this manifest itself as a humming tone?
Upon googling further, I found a common problem in the Z-2300 is a subpar mechanical joint of two ground wires. See Logitech Z-2300 subwoofer hum solved! | YourITronics. I replaced the mechanical joint with a soldered joint, but unfortunately this did not mitigate the humming.
I then spend some time measuring the power supply circuit of the Z-2300 with my DMM but I couldn't find anything suspicious: mains voltage appeared over the primary coil, the secondary was at 40.2V AC and I measured 54.2V DC after the bridge rectifier. Measuring the rails for the MOSFETs, my DMM reported an initially high ripple on the DC voltage but after a while the reading would stabilize to less than 1V (note this was with no outputs connected).
I then proceeded to try and de-solder the output caps on the bridge rectifier (in order to measure their capacitance, I don't own a ESR meter) but have been unable to desolder them due to all the epoxy on the PCB. As the two big caps still look in good condition in the pictures linked below, I'm doubting whether they are causing the humming.
The similarly between the humming from the transformer and from the speakers leads me to believe the transformer might be the culprit? While reading on transformer humming, I typically read about mechanical humming. In this case the humming from the transformer sounds more electrical though. Is there anything I can try to determine whether the transformer is the culprit? Unfortunately I don't have access to a bench power supply, I only have a DMM (though it can read capacitance and conductance).
Finally, can anyone suggest any further steps for troubleshooting the issue?
Link to imgur album.
edit: replaced images with link to imgur.
Old 7th January 2018, 10:22 AM   #2
R.I.P.
A 2pin mains plug tells you and us that you have a double insulated product that should have a double concentric square symbol on the labeling confirming this.
This is a ClassII product. DO NOT tamper with the existing mains connections !!!!!!
The third pin fitted to ClassI products is for SAFETY only. It has nothing to do with audio performance.
Again with ClassI products, DO NOT tamper with the existing mains connections.
regards Andrew T.
Old 7th January 2018, 10:26 AM   #3
R.I.P.
I am surprised to see 10000uF (10mF) 35V capacitors in there. That points to NOT penny pinching. A good sign that they have tried to do things right.
But you have used a remote server to locate your pics and they automatically download the full enormous data each time we log onto your page.
Please use the Forum's Attach process. And delete the enormous files.
regards Andrew T.
Old 7th January 2018, 10:38 AM   #4
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Samxon caps are (very) low quality.
I would replace or at least check them.
Old 7th January 2018, 10:42 AM   #5
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
The low frequency humming comes from the low quality PSU of your speakers.
Old 7th January 2018, 10:42 AM   #6
R.I.P.
No.
do not replace anything until after you find they are faulty.
Measure the Vripple at the smoothing capacitors. That will tell you a lot about how good, or bad they are. Armed with that information you can then make an informed decision on whether they are faulty and need replacement.
BTW,
There is a small cheap ESR meter described in this Forum. You can test Vripple (power ON) and ESR (power OFF) while the capacitors are still in circuit.
regards Andrew T.
Old 7th January 2018, 10:44 AM   #7
R.I.P.
I don't believe you.
Floris is probably correct in concluding (without much evidence) there is likely to be a wiring error.
regards Andrew T.
Old 7th January 2018, 11:40 AM   #8
Thank you everyone for your input, I've performed some additional measurements of the DC smoothing.
I have a fairly decent DMM which can measure ripple voltage on a DC voltage, though I doubt how to interpret its readings. Measuring the FET rails, it initially reports a large ripple voltage on rails but then the readings gradually lower until they are less than a volt and then they stabilize at this level (this decay appears exponential). This is confirmed by switching my DMM to DC voltage where it shows 54.17V across the power rails with a variation of 0.5V. This amounts to less than 1% of ripple. Is this problematic for audio amplifiers?
Measuring the DC voltage directly on the smoothing caps, my DMM reads 27.2V with +-2.5V variation for cap 1 and 27.3V with 2.6V variation for cap 2. When measuring over both capacitors I get the same reading as on the power rails of the mosfet; so 0.5V variation on 54.2V.
I'll try again to desolder the caps in order to measure their capacitance and I might look into the ESR meter if it's not too difficult to build.
@Andrew: you think there might be a wiring issue? Do you mean a component might not be probably grounded and that this could be the issue? I'm still thinking the toroidal transformer might be the culprit.
Old 7th January 2018, 12:58 PM   #9
I redid the measurements, as I misread the output from my DMM in my previous post:
Smoothing cap1: 27.4V DC, 0.05V AC
Smoothing cap2: 27.4V DC, 0.05V AC
Both caps: 55V DC, 0.1V AC
FET rail: 54.8V DC, 0.1V AC.
Strangely enough, repeating the measurements now (I just repowered the system, ok the FETs are running a little hot but nothing extreme) and all DC voltages are 0.6V lower ?
Old 7th January 2018, 01:24 PM   #10
Did you check this?
Troubleshooting low frequency humming in PC speaker setHide this!Advertise here!
Troubleshooting 35V on speaker output Wikeysz Solid State 17 24th April 2017 02:46 PM
Help troubleshooting CV LS-15 3-way speaker dietcola Multi-Way 0 26th May 2015 11:19 PM
Frequency Divided by 2 troubleshooting Hercules Digital Line Level 7 18th November 2008 05:19 AM
Humming Speaker Protection relay when powering up (newbie question) slowpoke-nl Solid State 4 21st November 2007 02:32 PM
New speaker prob, need troubleshooting help anonymoose Multi-Way 5 24th July 2005 03:43 PM
