Need help with a Alpine v12 f357
Thread Tools
Old 8th December 2017, 03:16 AM   #1
Dogerlee is offline Dogerlee  United States
Default Need help with a Alpine v12 f357
Ok here goes hollo every one first time post for a newbie,
I do have some electronics training even if it was twenty years ago but I do know what a multimeter is and how to use a iron and solder sucker ect ect
but here's my problem I picked up an Alpine v12 f357 amp at the local swap meet for cheap knowing that it had problems got it home opened it up and found some pwr transistors burnt now I have already ordered new transistors 44n's but I still have a few questions !st is there anything else that I should check besides the burnt transistors in the photos that I am sending with this post I was wondering if I should replace the diode to the right of the last burnt transistor I am not sure if it might have a problem due to the heat that it was exposed to the other thing should I replace all six of the transistors in this row or just the four that appear to have heat damage I think I should might as well do all six since I ordered ten of the things ? anyway, thanks for all of your help so far and I hope to hear from someone who knows just what I need to do.
R.Carsonm San Diego
Old 9th December 2017, 10:09 PM   #2
nigelwright7557 is online now nigelwright7557  United Kingdom
nigelwright7557's Avatar
Check the output transistors on a meter for shorts.
Sometimes the driver stage can be taken out too so check driver transistors.
Old 9th December 2017, 10:51 PM   #3
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
I would check power supply transistors also.
If you can get new output transistors, all of them, then measure the gain of each one and then match them accordingly.
Old 9th December 2017, 11:13 PM   #4
Thanks guys I will give it a check
  Reply to this post
Need help with a Alpine v12 f357Hide this!Advertise here!
Thread Tools
Alpine MRV-F357 S Merlington Car Audio 1 8th October 2014 06:41 PM
Alpine mrv f357 problems rdfenn3 Chip Amps 0 30th March 2013 06:42 AM
Alpine mrv-f357 thermal Kenc17 Car Audio 15 9th June 2011 06:44 AM
Alpine MRV-F357 Service Manual ACraig Car Audio 3 7th November 2009 09:19 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
