LM1875 layout
Could any1 help diy noob, would this pcb cover basic needs of lm1875 to work properly?
I like this board because it is speaker protection + power filter + both channels on same pcb.
I like that it has center ground point between main capacitors so i can connect all to that center ground.
I see it has c104 close to pins 3 and 5 to prevent oscilation + it has elect. caps near too
Zobel network is there so it is another +.
If any1 could spot some bad spots it would be great to point that out.
Sorry for my english and thanks.
PRR
Joined 2003
That's standard for the negative terminal these days.
Has been for 30+ years.
They have a roll of shrink tube with a "- - - - -" stripe to mark the negative leg. Often with a fat stripe so a wrong-way cap will stand-out on quick inspection of board.
I do not know why draftsmen mark "+" and cap makers mark "-". But we should be able to figure it out.
