Mod-286 build thread
Old 13th October 2018, 04:25 AM   #191
wcwc is offline wcwc  United States
I got a 330mm wide by 300mm deep mini dissipante. 4xMod-86, 200VA Antek transformer, and a Power 86 fit in there. Wiring will be somewhat challenging. Will have to mount the amp boards higher so that the back panel jacks are mounted above and below the amp modules.
Old 13th October 2018, 04:54 AM   #192
tomchr is offline tomchr  Canada
tomchr's Avatar
Oh, fun. I'm guessing you went with the 2U to challenge yourself. In the 3U you could probably just stack the boards on the heat sinks.
I'm looking forward to seeing your build pictures.
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω) at <-120dB THD. HP-1: 3W/20Ω, -130dB THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 13th October 2018, 05:47 AM   #193
I was originally only building stereo amps in the 2U chassis. That is much easier.
Nothing ever goes as planned.
Old 18th October 2018, 05:37 AM   #194
tomchr's Avatar
And just like that Rev. 2.0 is born: Neurochrome Modulus-286: 65W (8Ω); 125W (4Ω) @ <-120dB THD Composite Amplifier Module
I expect to open up for pre-orders over the weekend. I'm waiting for one quote to trickle in before I can lock in the pricing, but I'm thinking $350-375 is realistic. I'll offer these to the early adopters at a significant discount as a thank you for your patience as manufacturing will take a bit. I expect the modules to be in stock by the end of November. At that time the intro pricing will end.
Tom
Old 18th October 2018, 06:15 AM   #195
zman01 is offline zman01  Bangladesh
Tom,
The module looks nice and really compact. And I am sure it is not only about looks, but the well thought out engineering and design layout you have come up with to get top notch performance.
Old 18th October 2018, 07:16 AM   #196
tomchr's Avatar
Thank you. Yeah, I rather like it. The final version will feature the same end brackets as the Modulus-686 (see attached) and an aluminum back plate. All you have to do is give it a think coat of thermal grease and bolt it to the heat sink.
Tom
Old 21st October 2018, 02:50 AM   #197
tomchr's Avatar
In case you're looking for a deal on the new Modulus-286 Rev. 2.0 modules: I opened up for pre-orders this afternoon. The sale is on until 23.59 Mountain Time (GMT-7) on November 30th. Get yours here: Modulus-286: 125W composite amplifier achieving <-120dB THD
Tom
Old 21st October 2018, 07:09 AM   #198
Hicoco is offline Hicoco  France
Tom
Hi Tom do you sell the end brackets separately ?? thanks
Old 21st October 2018, 06:31 PM   #199
tomchr's Avatar
I do. You can find them as a "board option" for the Modulus-686: Modulus-686
Note that the brackets only fit the Modulus-186, Modulus-286 Rev. 2.0 (not the previous versions), and the Modulus-686. The 186 and 286R2 will come fully assembled, so you don't need to order the brackets separately for those.
Tom
Mod-286 build threadHide this!Advertise here!
Cheap (<100) Digital Tube Tester from ebay; experience/build/mod thread pauldune Equipment & Tools 21 17th April 2018 08:21 PM
Need help to build a system around Modulus-286 alexwey Chip Amps 11 26th May 2017 02:32 AM
rewiring a Sony PUA-286 tonearm eidling Analogue Source 1 8th October 2006 07:43 PM
