500 Watt Op Amps from Apex Microtechnology
Old 26th March 2004, 01:17 AM   #21
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally posted by speaker
Has anyone tried them on audio applications?
Haven't tried the high power modes like the PA-05 but I've been using the PA-02 and the PA-16 for quite a few years. I love 'em. They are a bit pricey though.
I first experimented with monolithic power opamps back in the early 90s. Then I tried a hybrid LH-0101 and found it much better than the monolithics I'd tried and haven't gone back to monolithics since. From the LH-0101 I went to the PA-02 and then the PA-16.
se
Old 26th March 2004, 02:23 AM   #22
jasonc is offline jasonc  Canada
Default Pa-02, Pa-16
Steve, could you please post a design?
Old 26th March 2004, 04:12 AM   #23
Steve Eddy's Avatar
Default Re: Pa-02, Pa-16
They're a power opamp so they can be used in most any of the various chip amp/Gainclone circuits. The only additional parts would be the two current sense resistors.
The amps I currently have built are just a simple inverting amp with a gain of 10 (input resistor of 10k and feedback resistor of 100k), 0.12 ohm current sense resistors and a Jensen JT-11P-1 input transformer on the front.
Don't worry about the extra pins I have labled for the intput and output. I use four pin Redel connectors on my stuff so that's why I drew the schematic that way.
se
500 Watt Op Amps from Apex MicrotechnologyHide this!Advertise here!
Apex power op amps redrabbit Chip Amps 21 9th May 2010 06:41 AM
Low/Mid-Watt Amps avt Tubes / Valves 4 7th July 2009 09:29 PM
240 watt, 24-db filter plate amps audiokinesis Swap Meet 3 11th September 2008 06:24 PM
apex jr alesis amps 2020audio Chip Amps 7 22nd June 2005 10:33 AM
Copyright ©1999-2019 diyAudio
