Ceramic Capacitor for audio input
Old 12th May 2017, 09:51 AM   #21
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
If you need small SMD capacitors for coupling why not a film one like Cornell Dubilier FCA, Wima PPS or Panasonic ECW (all available from Mouser)?
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 12th May 2017, 12:04 PM   #22
DUG is offline DUG  Canada
From Murata's web site
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 12th May 2017, 02:31 PM   #23
R.I.P.
Murata's plots are typical of Hi K ceramic.
X7R perform quite a bit better and when used on a near constant DC supply voltage have near zero capacitance change. eg a 220nF 50V cap on a 35V supply might have an installed capacitance of 170nF, but stays near that value because the DC stays near it's normal operating value.
For audio passing capacitors one can use the Lo K Class1 ceramics designated NP0/C0G both for filtering duty and/or for coupling duty.
Now that MLCC are available you can get higher NP0/C0G values that were rarely seen 10years ago.
regards Andrew T.
Old 12th May 2017, 03:20 PM   #24
infinia is offline infinia  United States
infinia's Avatar
are you sure
remember the OP wants >1uF range
Old 12th May 2017, 03:23 PM   #25
OlegSh is offline OlegSh
The biggest value NP0/C0G SMD cap that is available from mouser is 0.47uF. It is 2220 size which means that the board area would be smaller if 5mm leads pitch polyester film cap is used instead.
Old 12th May 2017, 03:43 PM   #26
infinia's Avatar
So the OP needs 2 of them at 4 Euros a piece
Any manufacturing engineer would be hung if he dared specifying 2 of those,
but hey this audio.
In modern SMD mobile phones they use solid tantalum here for audio / headsets.
Old 21st May 2017, 10:05 AM   #27
basreflex is offline basreflex  Spain
X7R and X5R are well known for their capacitance vs voltage characteristics.
so it is important that the voltage across the cap does NOT change, to have a stable capacitance, and reduce modulation of series impedance with momentary voltage. (distortion). so first is to determine wether the voltage changes, and that is only at low frequencies (coupling) or when used in filters. this means you can safely use these ceramics in coupling stages, but not use them as high pass filters. so overrate the value at least 10x (or HP freqs < 1hz), plus some marging for the curve if there is a large dc difference across the cap.
Ceramic Capacitor for audio inputHide this!Advertise here!
which ceramic capacitor for PA03 clog Chip Amps 10 19th October 2015 08:13 AM
ceramic capacitor Vrystaat Solid State 9 3rd October 2012 07:39 PM
Ceramic capacitor non-linearity jackinnj Power Supplies 18 7th September 2011 02:10 AM
av400 ceramic capacitor sterky Parts 0 8th June 2010 07:02 PM
ceramic capacitor zahlm Parts 0 18th June 2004 09:43 PM
Copyright ©1999-2019 diyAudio
