LME49811
As for the LME49811 being available again, you could look here
LME49811 – Buy LME49811 with free shipping on AliExpress
Hi Guys!
I'm back on the project trail building a digital pre-amplifier for my Q-Watt, somewhat based on: https://sound-au.com/project163.htm
I'm looking for decent quality RCA panel-mount connectors, and I can't remember what I used on the Q-Watt.
Do you have any recommendations in the range 8-12 GBP per pair?
Pops.
Pops.
Hello!! Nothing to report on Q-Watt. I've not needed to open it up for years. I do switch it off daily to save 25W idle power consumption, so the soft start is getting some exercise.Q Watt report. Working superbly every day since built!
I am building a digital preamp and analogue switch based on PGA2311. 2-channel prototype is complete including software, and works brilliantly.
Uses optical encoder as volume control and infrared too. Offers 0.5dB steps in attenuation (or gain) with very low THD.
Am just now designing new circuit boards. I should start a new thread. Power supplies are both from ESP, and in fact the whole idea is based on ESP P163: https://www.sound-au.com/project163.htm.
Great to hear from you!
Popchops
Hi Popchops. Quite a build i see. Good luck on that!
I started on a Valve Amplifier by http://tubelab.com/designs/tubelab-spp/
I've got most of the parts minus the Transformer, that are stuck in the very very slow Spanish postal service.
- Chip Amps
- My Q-Watt project
