Neurochrome LM3886DR Build
Old 13th September 2020, 04:31 AM   #451
tomchr is offline tomchr  Canada
tomchr's Avatar
Yeah. I think step 5 should have been:
5. Electrolytic capacitors: C2, C3, C11, C13, C14, and C15.
Typo on my end. My bad.
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 13th September 2020, 05:07 AM   #452
DaveFred is offline DaveFred  Canada
Two boards almost done!
Old 14th September 2020, 11:12 AM   #453
Before soldering the chip to the board, I screwed the board and the chip to a piece of plywood so they would all lay flat on the side of the heatsink.
Soldering the boards is the easy part compared to putting it all in the case.
Lots of put the case together/take the case apart, rinse/repeat...
Doesn't help that I have not built any other amp before and don't really know what I am doing.
I marked/drilled/tapped all the mounting holes in the heatsink to mount the boards, chips and a couple of brackets to hold some wires.
Old 14th September 2020, 02:16 PM   #454
asuslover is offline asuslover  Romania
Looks very good, one thing I would do different ....instead of mounting the chip and the board on a piece of plywood I would use a piece of aluminum flat bar or the actual heatsink.
Can you share with us what brand of the Drill Tap you are using, looks like you did a great job with that.
Old 14th September 2020, 04:23 PM   #455
I am using USA made Champion tap and drill bit.
What made the biggest difference was the tapping fluid/oil, it went from hard to turn/lots of torque required/I can see the tap twisting/OMG will this snap? to, easy to turn with massively lower resistance.
Old 15th September 2020, 12:11 AM   #456
Tom
Why do you use a clip to hold the chip against the heatsink rather than directly attaching it with a screw?
Old 15th September 2020, 12:20 AM   #457
454Casull is offline 454Casull  Canada
Not Tom, but one reason is that you'll never lose screw tension through heating and cooling cycles. You also get a bit more wiggle room if the screw is improperly located.
Old 15th September 2020, 01:05 AM   #458
tomchr's Avatar
The wiggle room is the biggest reason.
Always, always use cutting fluid when cutting threads. I use Relton A-9 Aluminum Cutting Fluid (not to be confused with A-1 Steak Sauce ).
Tom
Old 15th September 2020, 04:19 AM   #459
I added the volume knob to the front plate tonight.
There is a very common volume knob extension available online and I bought one, but I didn't like how much play there was between the bushing the the shaft.
So instead, I bought a linear bearing from a 3D printer that rode on a 6mm shaft and mounted it to the front plate from behind. The picky me wanted to tap blind holes for the screws that held it, but the practical me won and I did through tapped holes knowing the front knob would hide the holes.
Much less play with this set up.
Old 15th September 2020, 02:34 PM   #460
Very clever. I probably would've gone with a ball bearing myself but your way seems to require less work. How does it "feel" in rotation?
Neurochrome LM3886DR BuildHide this!Advertise here!
Neurochrome LM3886 Done Right - 45 W, 8 Ω, 0.002 % THD+N; 80 W, 4 Ω, 0.004 % THD+N tomchr Vendor's Bazaar 32 31st August 2020 05:49 PM
Neurochrome Parallel-86 Group Buy tomchr Group Buys 55 23rd August 2019 09:14 AM
Neurochrome Differential preamp build IanLenco Analog Line Level 39 10th March 2019 06:08 PM
FS: 4 channels of Neurochrome Mod-86 amp kits tubesguy Swap Meet 4 7th April 2017 04:46 PM
FS: Full set of Neurochrome PCBs (Parallel-86, Power-86, THAT Rx) FJHookah Swap Meet 5 7th July 2016 08:15 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
