Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
#21 |
This is very interesting - details?
#22 |
Saw your amp. Very brave to mount it on a CD. I like the way you put the power supply inside the case, but what do you think of fire hazards -
TDA 1519AQ |
#23 |
Update: it is possible to run the amp off a 9V DC suppy. Tested with a 9V battery and it works.
I will be installing the electronics in a larger amplifier case. |
#24 |
I tore apart a set of Sony computer speakers and stole the amp. The power supply was a 9 volt D.C. wall wart. I use a LM7809 regulator for a cheap way to operate the amp from my 12 volt house battery. Not the most efficient regulator but it was easy to find and use at the time..
The D.C. input to the regulator can be anywhere between 10 to 32 v.d.c. and will handle a 1 amp load with a heat sink. In most cases with small amps, the heat sink is not needed.. I found these little guys and have used them many times. Very reliable and versatile. Shop around and you can find them much cheaper.. 10pcs RC Airplane Module Mini 360 DC Buck Converter Step Down Module 4.75V 23V to 1V 17V 17x11x3.8mm New LM2596-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group |
#25 |
Nice to see some pictures if you have them. I take it you are off grid - so the low power amp makes a lot of sense - and a lot of noise for a small amp.
Edit- Noise means music output not the bad kind. |
#26 |
I took one of these and made a portable test amp from it. It operated from 4-"AA" cells or 6 volts. I hot glued a LM7806 in the battery holder area and connected the output of the regulator to the proper battery connections. Took the speakers and housings off of the main case and ran a length of wires from the amp to connect to speakers. Worked out well..
![]() Here's one project that I did with the amp.. https://imageshack.com/a/XD0q/1 And yes.. I'm totally off the power grid and have been since 1989. Whole system operates at 12 V.D.C. Last edited by OffGridKindaGuy; 29th March 2016 at 02:06 PM. Reason: 'Cause I Could.. |
#27 |
So you made a boombox. I was thinking more on the lines of a mini-hifi system like these
Best mini hi-fi systems reviewed: Panasonic, Denon, Cambridge Audio and more (Wired UK) Its difficult to maintain an entire family off grid, the TV becomes an essential item. |
#28 |
If you have a design for an amp/source combo, you can connect to many different types of standard house speakers. That little ElCheepo that I converted was , at one time for giggles, connected to a large set of Klipsch floor standers. The amp just increases the noise that you put into it. You have choices of what to connect the amp to. Just use your imagination and play within the limits of the amp..
You'll love this. A bare bone $.34 - 5 volt chip amp (3w/Ch.) with a USB Bluetooth receiver as the audio source driving 4 Kenwood surround sound speakers. (4 Ohm/Channel) 2 bank batteries can make a lot of noise! Sounds impressive.. ![]() https://imageshack.com/a/IZw4/1 I have a 74" projection TV/DVD system in my living room. It draws ~7 amps through a 12-19.5 volt converter from my battery. I use a Jensen motorhome head (AWM975) for the audio/video which drives 4 speakers. (2 Klipsch and 2 RCA) All remote control.. I also have a 19" TV/DVD combo in the bedroom mounted to a hinged arm above the bed. 2 Sony speakers mounted to the ceiling with a Lepai LP-808 amp. Source is the TV headphone jack through an isolation transformer to avoid ground loop issues. (They both power from the 12 v.d.c. house battery direct) Amplified outdoor antenna system supplying both.. The imagination is a beautiful thing.. Last edited by OffGridKindaGuy; 30th March 2016 at 02:45 PM. Reason: 'Cause I Could.. |
#29 |
All this off Solar power? Impressive. I am looking into going for a daytime solar system to reduce costs - maybe discuss this on the Everything Else - diyAudio ?
#30 |
Sure.. Get a thread going. Maybe we can draw out some others around here that are using solar or other power sources..
Most every project I build is battery powered and portable. I only have one 120 v.a.c. power strip connected to a 400 watt inverter. Might use it once a week.. (Or when I'm soldering) I've purchased brand new audio items, took them home and immediately torn them apart to convert them. Makes my wife cringe.. ![]() |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Speaker arrangement for vintage radio conversion | peacocksuit | Multi-Way | 9 | 6th December 2015 11:29 AM |
Simple PC System Speaker Amplifier | Osvaldo de Banfield | Digital Source | 0 | 3rd April 2012 05:09 PM |
3-pong conversion for Acoustic amplifier | engels | Tubes / Valves | 2 | 22nd May 2007 02:06 PM |
At Pc Power Supply Conversion??. | Marvellous | Power Supplies | 4 | 16th March 2007 12:04 AM |
Car and Home Speaker Conversion | dirtymexican | Multi-Way | 8 | 17th May 2006 04:33 AM |
New To Site? | Need Help? |
