Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
I'm thinking of buying a 2x 68Watt LM3886 + NE5532 power amp board like this:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
But it doesn't have volume/tone control, so I'd like to buy a tuning board like this:
It is based on LM4610N and NE5532 and has bass, treble, balance volume and surround sound. Can I connect its output to power amp input? If so what should I look out for when mating those 2 boards? Thanks for any suggestions |
#2 |
yes you can connect them.
i don't think you need anything special.
V*A=VA V*A*PowerFactor = WATT |
#3 |
The surround signal will not be used unless you purchase another amplifier.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk |
#4 |
#5 |
the LM4610N has 2 output channels.
virtual sorround will work, you do not need a nother power amplifier. there is no reason why you would need a notherone.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Will this class D setup work? Help a noob out :) | Mark Communifi | Class D | 4 | 29th May 2015 07:51 AM |
Isobaric loading, would this setup work??? | swin1 | Multi-Way | 3 | 20th May 2006 04:58 PM |
Need Help if this setup work! | pinoy82 | Multi-Way | 3 | 6th November 2002 02:18 AM |
New To Site? | Need Help? |
