OPA445 as building block
Has anyone used the OPA445 as the "driver" in a power amp? What voltages did you feed it? The datasheet says abs. max 50V each rail, and I was thnking of feeding it 48V each rail so as to make a 200W/4R audio amp!
I find OPA453 has better bandwidth in circuit.
OPA453 can take +/- 40 Volt supply.
But as I said, you get better frequency with OPA453.
OPA453 can deliver 50mA and it is one TO-220 capsule.
http://www.ti.com/lit/ds/symlink/opa452.pdf
Here is one example of using OPA453 as power amplifier.
Give it a try.
