chipamp suggestion for 3w 4ohm
Old 3rd March 2015, 03:13 PM   #1
zany7 is offline zany7  United States
Default chipamp suggestion for 3w 4ohm
Hey there guys im having a tough time building an amplifier for my 3w 4ohm speakers. I previously used tda2050 and it didn't work maybe a fake ic. i want build my amp with a suitable chip. Im okay with class d and class ab.
Old 3rd March 2015, 07:05 PM   #2
phase is offline phase  United States
I'll bet an ebay tda7297, or a ta8250 pre-made board would work.
Don't let the 15w ratings scare you, would work fine with a 1 or 2 amp power supply and those speakers.
Old 3rd September 2015, 02:15 AM   #3
tedkok is offline tedkok  Hong Kong
you can try a new linear amplifier IC
CS6A4989
from Canaan Semiconductor which is available from Profusion or Clere.
Datasheet is available at
https://www.profusionplc.com/images/...heets/cs4989_b
Old 3rd September 2015, 02:24 AM   #4
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
The DS for that chip is full of contradictions, doesn't engender confidence that the designers knew what they were doing.
Just a couple of examples - the absolute max supply is 38V but when shown as two separate supply voltages, the max is +/-12V. The abs max junction temp is shown as 70oC but the highest recommended ambient operating temp is 75oC.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 3rd September 2015, 03:39 AM   #5
It seems that Profusion is not hosting the latest datasheet.
You may find the latest from canaan's website
http://www.canaan-semi.com/_media/CS...B_19Jun15a.pdf
Demo board of this amplifier is available from Profusion, and
Clere, Have a try.
Old 3rd September 2015, 02:25 PM   #6
johnr66 is offline johnr66  United States
The OP is probably long gone, but look at the LA4425A. It 5 watts but at 12.6 volts you will actually only get about 3 clean watts into 4 ohm loads. Very simple low part count fixed gain IC. Works good in the post TDA2003 era aside from having a bit too much gain.
Old 22nd April 2016, 12:57 AM   #7
A 4W @4ohm amplifier module that use CS6A4989 is now available in
http://www.eltim.eu/data/mediablocks...%20PA-4989.pdf
It's linear, low distortion and power efficient.
Old 22nd April 2016, 07:41 PM   #8
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Howabout that wee PAM class d amp? That is already built.
chipamp suggestion for 3w 4ohmHide this!Advertise here!
How much volume do I get for 3w RMS? gasboss775 Multi-Way 9 2nd March 2015 11:09 AM
Increasing power of PAM8403 3W+3W amplifier board Wilfrid Class D 5 1st February 2015 02:57 PM
TDA2030 for 3w speaker maher471 Chip Amps 15 14th July 2012 01:04 PM
Source for 3W resistors seve Parts 4 12th February 2006 01:23 PM
3W instead of 5W in Aleph 5? dantwomey Pass Labs 3 31st March 2003 11:52 AM
Copyright ©1999-2019 diyAudio
