LM3886 & LME49720 composite amp
Old 2nd February 2015, 09:49 PM   #21
jcx is offline jcx  United States
snowy day, hadn't fired up LTSpice in a while...
can't see how its going to be stable
the dotted box is a crude linear "macro model" for LM3886 with enough excess poles that it is unstable at below ~ Av 5
happy with gains of 10+ like expectation from the data sheet min gain spec
if you have a stable prototype it aint wired like the pdf, from my sim
Old 2nd February 2015, 09:56 PM   #22
IO390 is offline IO390  United Kingdom
IO390's Avatar
I have built 4 of these boards so far and I'm listening to them right now.
It's stable...
io390.co.uk
Old 2nd February 2015, 09:58 PM   #23
so show me the sim or circuit error
Old 2nd February 2015, 10:00 PM   #24
IO390's Avatar
Huh? I never simmed this circuit, it's not complex enough to need it.
io390.co.uk
Old 2nd February 2015, 10:05 PM   #25
my sim .asc file is right there for any to download, dissect show me the error
until then I maintain you didn't build that
whatever you did build, are listening to ain't the circuit shown
Old 2nd February 2015, 10:07 PM   #26
IO390's Avatar
Jesus... Am I getting accused of not building the circuit I said I did?
I don't even see the point in that.
io390.co.uk
Old 2nd February 2015, 10:15 PM   #27
its possible there are wiring and/or component value differences from the circuit shown and what you have
but it seems rather unlikely you have a non-oscillating build to the shown circuit diagram
so until anyone can show me my sim error I have to give the warning
Old 2nd February 2015, 10:24 PM   #28
IO390's Avatar
So you're saying that I built AND published a circuit that doesn't work.
As I say, I've built 4 boards thus far (a friend is building another two), AND a point-point prototype so I'd know if I had made an error in component values.
I am well aware of how good LTSpice is, but you're testing a circuit with a different opamp model and an approximate LM3886 and yet you say that your simulation emulates my real life circuit?
Your LTspice model does not take into account the internal compensation of the LM3886 for example.
io390.co.uk
Old 2nd February 2015, 10:34 PM   #29
the integrator feedback around the LT1469 renders the exact op amp pretty irrelevant
my LM3886 model isn't what I would call pessimistic but there is the possibility that all parts built today on modern processes are better than the typical specs in the decades old datasheet
but as an engineer I expect to actually design to worst case datasheet info with a margin
I wouldn't recommend building that circuit, with those values to any manufacturer as a safe practice
can't see giving a pass to anyone recommending such to hobby builders with even less electronic design sophistication, or even a decent oscilloscope
Old 2nd February 2015, 10:38 PM   #30
IO390's Avatar
True
Probably not the case IMO.
Fair enough if you wouldn't recommend it. I'm not saying anyone should build it and I'm not here to sell it. I posted it here in case it interests anyone, and if they build it and like it then great.
But there's no point in saying it won't work and must be unstable because of some approximations you've made. If you build it and then find problems then great, I will accept that. It's things like this that deter me from posting on this forum (and most other forums).
io390.co.uk
LM3886 & LME49720 composite ampHide this!Advertise here!
An LM3875 composite amp dellama Chip Amps 41 8th November 2014 11:17 AM
Bridged LM3886 + LME49720 + remote FB iggy111 Chip Amps 32 2nd September 2014 12:14 PM
LME49720 Pre amp PCB/Kit Jsixis Analog Line Level 23 19th April 2014 11:44 AM
how about LME49720 driving LM3886? mondogenerator Chip Amps 3 16th April 2010 07:31 AM
Copyright ©1999-2019 diyAudio
