Modulus-86  build thread
Thread Tools
Old 18th September 2021, 03:59 PM   #5671
tomchr is offline tomchr  Canada
tomchr's Avatar
You would be better off adding gain in the preamp. The reason is that if you increase the gain of the MOD86 you amplify its noise (which is ~30 dB higher than that of the Universal Buffer already). If you add a Universal Buffer (even with gain) you will not add appreciably to the output noise of the overall system because the Universal Buffer's noise is way below that of the amp.
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
  Reply to this post
Modulus-86  build threadHide this!Advertise here!
Thread Tools
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2478 16th February 2021 05:04 PM
Build Thread: OBEOS Tytte71 Multi-Way 15 1st October 2011 06:02 PM
Dome's Build Thread. joe58 Full Range 12 1st September 2010 04:05 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
