Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
#5291 |
What kind of wires are recommended for connecting the transformer inputs and outputs, the power module and the amplifier modules?
I sourced some AWG20 and AWG18 cables from an old tower PC but I don't know if the gauge is big enough and if solid core is preferred over stranded. Also, from what I understand the transformer input and output should be twisted and preferably shielded. Thanks! |
#5292 |
Stranded vs solid: Meh. The electrons won't care, so use what you have handy. I prefer stranded because I find it easier to work with.
20 AWG would be perfect for the input, but is a bit skinny for the power supply and speaker connections. Some (me included) would prefer shielded cable on the input, though. I generally use microphone cable for this, though in my most recent build I used star quad cable. I generally use AWG 16 for the speaker connections. Some may prefer heavier gauges. You can always use 2-3 18 AWG in parallel and just zip tie them together. The wires on the transformer itself are generally long enough to reach. They need to be tightly coupled. I run them parallel and zip tie them together. I doubt you'd be able to get a tighter coupling if you twisted or braided them together. Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886. Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right Last edited by tomchr; 2nd November 2020 at 06:27 AM. |
#5293 |
Awesome, thanks Tom!
#5294 |
Hello to all, long time i did not share, neither did i progress on my project due to unexpected events
Project is double mono mod86 I was going on using a smps300rah 30V per each mod86 amp Would the SMPS240QR 30V be Ok? Instead of the smps300rah? What would be thz difference? Thanks |
#5295 |
Also, i olan to use a alps rk27 connected to the RCA inputs ( so directly to a dac) to control volume, is it problematic? Impedance level or so?
#5296 |
Nope, no issue
#5297 |
Grace mille, so i can go route of control volume with alps rk27 connected to rca
What about differences between smps300reh and smps240qr , both in 30v? |
#5298 |
Sorry push .. its black friday and smps240qr is currently on sale .. i need two
Originaly, i was planning on two smps300eeh @85 euro each .. so 170 boths .. Smps240qr now sale for 45 each until sunday .. so thats a nice saving over my original plan But i just dont know if they ok since i read on this thread that smps300reh was suitable |
#5299 |
I used the SMPS 240 in my mono 86's and they seem fine. Quite and small so easy to put in small enclosures. No idea if the 300's would have been better though. Photos and more info my construction in earlier posts.
#5300 |
Ok, sounds fine to me if someone uses the smps240qr
Unless someone raise hand before sunday and inform its better to fo with two smps300reh ,i'll go with a 240qr per channel Thanks |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. | tomchr | Vendor's Bazaar | 2475 | 28th November 2020 05:02 AM |
Build Thread: OBEOS | Tytte71 | Multi-Way | 15 | 1st October 2011 07:02 PM |
Dome's Build Thread. | joe58 | Full Range | 12 | 1st September 2010 05:05 PM |
SE - Build Thread | soundengine355 | Solid State | 6 | 27th June 2009 01:19 AM |
New Project Build Thread | ryoung | Multi-Way | 5 | 19th April 2008 02:15 AM |
New To Site? | Need Help? |
