Modulus-86  build thread
Old 11th December 2019, 06:54 AM   #4931
spiggs is offline spiggs  United States
I am going to use the SMPS-86 to power my Modulus-86. My plan is to reuse a case I made for an ACA. It has a front mounted SPST on-off style switch for power on. I would like to keep the switch as the power on for the Modulus-86. Is there a ready made way to hook this up?
Old 11th December 2019, 01:18 PM   #4932
craigtone is offline craigtone  United States
craigtone's Avatar
There is a spot on the SMPS to mount a RA switch. Just wire the switch you have externally to the PCB pads.
Craigtone Audio
Soundsmith Boheme, WT Classic, OPENAMP1, Apollo-R, Burson Swing Everest, Hafler 915, TSE 45, ALK Klipschorns
Old 11th December 2019, 03:21 PM   #4933
The switch pad is setup for a dpdt switch unless I am missing something.
Old 11th December 2019, 03:28 PM   #4934
craigtone's Avatar
Yes. Just jumper the Neutral across the switch leads on the PCB and switch the Hot if your chassis switch is SPST.
Craigtone Audio
Old 11th December 2019, 05:35 PM   #4935
Got it, thank you.
Old Today, 05:05 PM   #4936
craigtone's Avatar
I just listed a Power 86 PCB, parts kit and AS-2222 transformer in the Swap Meet if someone wants to save a few bucks on a build!
Craigtone Audio
Modulus-86  build threadHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2446 8th December 2019 12:55 AM
Build Thread: OBEOS Tytte71 Multi-Way 15 1st October 2011 07:02 PM
Dome's Build Thread. joe58 Full Range 12 1st September 2010 05:05 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 01:19 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 02:15 AM
Copyright ©1999-2019 diyAudio
