Modulus-86  build thread
Old Today, 07:04 AM   #4731
MrKettle is offline MrKettle
Out of interest while on the subject of wire links, are there differences in the THAT chips which means that the 1203 and 1206 need the zeners and the 1200 doesn't? I might be fiddling around with preamps in the future which could mean changes to the optimal gain in the power amp.
Old Today, 10:17 AM   #4732
tomchr is offline tomchr  Canada
tomchr's Avatar
Yeah. The THAT1203 and THAT1206 have different gains. -3 dB and -6 dB, respectively. This means the inputs should be allowed to swing past the 17 V supply rails. Installing the zener diodes allows this to happen. If you never exceed 17 V peak on the input, you can leave the wire links in.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD. HP-1: 3W/20Ω, -130dB THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old Today, 02:43 PM   #4733
If my maths is right, 17V input gives of the order of 3.6kW output into 8 ohms. I don't think my system and listening habits would require that....
Old Today, 04:00 PM   #4734
BrianL is offline BrianL  United States
You're not considering potential large common-mode signals as well as other scenarios. Tom uses the THAT parts in a (home) audio power amp, but the THAT chips were designed with the pro audio market in mind and they have many more use cases to consider.
bel
Modulus-86  build threadHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2421 17th May 2019 12:10 AM
Build Thread: OBEOS Tytte71 Multi-Way 15 1st October 2011 06:02 PM
Dome's Build Thread. joe58 Full Range 12 1st September 2010 04:05 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
Copyright ©1999-2019 diyAudio
