Modulus-86  build thread
Old 16th November 2018, 12:29 AM   #4381
Panelhead is offline Panelhead
Sometimes hear people comment that some passive parts are directional. Resistors, film caps, even wire have a direction. I orient with the printing readablefrom source to output just in case.
I really doubt these passives are directional. Especially with ac signal.
I do truly beleive the polarized caps, diodes, and regulators are directional.
Hope this helps.
Cheapest is bestest
Old 16th November 2018, 12:33 AM   #4382
Originally Posted by tomchr View Post
Those who'd like a bit more of a turnkey build experience should consider my newly launched Modulus-186 and Modulus-286 Rev. 2.0.
The intro sale will close by November 30th. I expect to have the modules in stock by then.
The Modulus-186 is basically a Modulus-86 in SMD, professionally assembled. I've started a separate vendor's thread for it.
Tom
I am going looking. The turnkey is not an interest, but using SM should allow shorter paths and better performance. That seems to be key will these composite amps.
Cheapest is bestest
Old 16th November 2018, 02:02 AM   #4383
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by cloud1972 View Post
hi folks just building amp 86 is the direction of c10 (wima film capacitor) important if so which way round should it go
Nope. Film capacitors are not polarized.
Passives such as resistors and film/ceramic/mica capacitors are not polarized. I generally install them such that they are all easy to read for verification and troubleshooting.
Semiconductors and electrolytic and tantalum capacitors are polarized, thus, must be installed following the markings on the board.
Note that some believe passive components "sound better" when oriented one way or another. To the best of my knowledge, there is no science to back up these claims.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD. HP-1: 3W/20Ω, -130dB THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 16th November 2018, 02:04 AM   #4384
tomchr's Avatar
That's part of the design for sure. You'll find the Modulus-186 and -286 vendor threads here:
Neurochrome Modulus-186: 40W (8Ω); 65W (4Ω) @ <-120dB THD Composite Amplifier Module
Neurochrome Modulus-286: 65W (8Ω); 125W (4Ω) @ <-120dB THD Composite Amplifier Module
Pictures show the prototype builds of the two amp modules. The final version will feature Neurochrome Blue circuit boards and metal back LM3886es (LM3886T/NOPB, to be specific).
Tom
Old 16th November 2018, 08:00 AM   #4385
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
Video over at YT Are Your Capacitors Installed Backwards?
LINK: YouTube
Old 16th November 2018, 01:51 PM   #4386
asuslover is offline asuslover  Romania
Byrtt, thank you for that link!
Old 16th November 2018, 02:34 PM   #4387
tomchr's Avatar
I'd add a correction to that video. I didn't watch the full 45 minutes of it, but in the introduction he mentions that film caps have a polarity. That's incorrect. What they do have is two sheets of film rolled up with a sheet of dielectric in between. As result, one sheet of film/foil will be on the outside. You can reduce hum pickup (important in phono stages and tape circuits) by grounding the outer foil in cases where the caps connect to ground. In those cases, there's usually a marking on the package to indicate which lead is connected to the outer foil.
When in doubt, check the manufacturer's data sheet.
For the capacitor in question in the Modulus-86, there is no polarity. It can be installed either way.
Tom
Old 16th November 2018, 02:43 PM   #4388
zgtc is online now zgtc  Europe
zgtc's Avatar
Yes, that's the theory, but what that video shows is that these indications are often wrong. If that is really the case, it looks quite surprising to me that no one else had ever noticed this behaviour. Looks quite "suspicious" to me at the very least.
Old 16th November 2018, 02:56 PM   #4389
BYRTT's Avatar
@asuslover, welcome.
@tomchr, about that video also will guess we go in small shoes here regarding application of modern small footprint circuits as your modules
Many years ago myself diy some tube guitar amps including overdrive stages that is not especially silent as is, maybe that application will benefit a recheck of how coupling caps are wired up.
Old 16th November 2018, 11:19 PM   #4390
cloud1972 is offline cloud1972  United Kingdom
thanks guys for the info it was the small dot on the one side of the cap that made me question direction so thanks for the help
Modulus-86  build threadHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2409 23rd November 2018 03:49 AM
Build Thread: OBEOS Tytte71 Multi-Way 15 1st October 2011 07:02 PM
Dome's Build Thread. joe58 Full Range 12 1st September 2010 05:05 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 01:19 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 02:15 AM
