Modulus-86  build thread
Old 24th September 2018, 09:57 PM   #4361
pistollero is offline pistollero  Portugal
Originally Posted by tomchr View Post
No need for any additional components on the differential lines. Just build the Modulus-86 according to the BOM and plug its input into the differential output of your DAC.
Mostly by routing magic smoke between devices. It's that smoke that you let out when the part fries. Gotta keep it inside the part. This is important!
On a serious note: There's good description of how the THAT1200 works in its data sheet: THAT Corporation 1200-series InGenius High-CMRR Balanced Line Receiver ICs
Tom
Ok tks!
I measure 2.9 dc volt between + and ground and - and ground.
Do i need to connect ground???
With transformers i only connect the + and - , not the ground.
Old 25th September 2018, 12:42 AM   #4362
tomchr is offline tomchr  Canada
tomchr's Avatar
Directly from the design documentation. Notice the filled solder dots on the ground connections to the chassis. That means you have a connection there. This is also described in the text.
Tom
File Type: png Screen Shot 2018-09-24 at 18.41.10.png (268.4 KB, 370 views)
MOD686: Up to 240W/8Ω, <0.00025% THD. MOD86: 40W/8Ω, 0.000054% THD. HP-1: 3W/20Ω, -130dBc THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 25th September 2018, 07:52 AM   #4363
Tom
Ok i understand that but i don t have chassis. I have all the boards on a wood base.
In that case what is the best way to do?
Right now i connected the ground from analog dac ps to modulus 86 xlr ground by wire....
Old 25th September 2018, 05:41 PM   #4364
tomchr's Avatar
In that case the DAC supply ground should go to the MOD86 supply ground. DAC signal ground should go to pin 1 of the MOD86 input. Signal+ should go to MOD86 input pin 2 and Signal- to pin 3. If the DAC does not have differential out, take the DAC signal ground to MOD86 input pin 3.
Tom
Old 5th October 2018, 02:00 PM   #4365
wcwc is offline wcwc  United States
If I ran 4 Mod-86's off a 2x22 200VA transformer and a Power-86 would I get full output from all 4 channels? It would probably be temporary for running the Lx-mini's until I save up enough money for the 686/186 combo.
Old 6th October 2018, 04:25 AM   #4366
tomchr's Avatar
Yep. A 200 VA transformer is enough for 4xMOD86 with all channels playing music at clipping level into 4 Ω loads. Thus, it's plenty for driving the LXmini (which uses one 8 Ω and one 4 Ω driver).
Tom
Old 6th October 2018, 05:56 PM   #4367
So I have a 2U minidissipante enclosure with the 300mm long heat sinks. The layout seems to work best with 3 mod-86 boards on one heat sink. It looks like it should work based on the calcs if I use the 2-8ohm and one of the 4 ohm boards. 0.45 C/W for the heat sink.
Old 6th October 2018, 08:02 PM   #4368
tomchr's Avatar
Yep. That'll work. You can then entertain the idea of building a 6-channel amp in one chassis. That'd be perfect for a stereo pair of LXmini+sub. Use my Power-686 for the supply with a 2x22 VAC @ 300-400 VA transformer.
Tom
Old 6th October 2018, 08:31 PM   #4369
Need to have the wider amp chassis to fit in 6 channels. I ordered the analog crossovers from the DIYAudio store (someday it should show up) which are only the 2 channels. I will try that out first. Running balanced so I picked up two boards. Long term idea was to put the crossover in a similar size chassis under the amp. When I add subs I will most likely use dsp and a classD amp that I have. The studio driver is a bit pricey, so I will most likely try something less expensive. So 2 channels per lx-mini speaker seems OK, but we will see how things play out. First thing is to get the lx-mini drivers and build it.
Modulus-86  build threadHide this!Advertise here!
Modulus-86: Composite amplifier achieving <0.0004 % THD+N. tomchr Vendor's Bazaar 2407 12th September 2018 04:27 AM
Build Thread: OBEOS Tytte71 Multi-Way 15 1st October 2011 06:02 PM
Dome's Build Thread. joe58 Full Range 12 1st September 2010 04:05 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
New Project Build Thread ryoung Multi-Way 5 19th April 2008 01:15 AM
