Bridged LM3886 + LME49720 + remote FB
Joined 2018
There are more than 1000+ builds of BatoMM around the world, after 1000 we stopped counting ... :)
Almost 2MIL views on our local (private/dev) forum just BatoMM thread, almost 5000 thread replies just for that particular amplifier ...
If you were building the amp for an unknown speaker (could be 3.5-8 ohms) what voltage and VA transformers would suggest for a pair of them?
With the above transformers, what would the expected watts be at 3.5 or 8 ohms?
(amp would be used with a large variety of speakers...)
Thank you,
David.
For those who looking for new version v1.5 it will be on git soon! I'm just finished new layout. Added some trought hole options including dip-8 socket, now you can solder TH, smd, or booth condensators, soic-8 opamp or dip-8, Scan qr code for link
Reactions: 1 user
Seems Yu3ma is busy and not updated their github page but here is version 1.5 carefully designed, some components is trought hole and/or smd, your choice, for example opamp dip vs soic, your choice which one you going to solder, enjoy!
  • BOM_BatoMM-V1.5_2023-02-14.txt
  • Gerber_lm3886-bridgeV1.5_14022023.zip
